Hello All!
I have been lurking for quite a while, and I'm finally about to start on my first build: The GoW (Galley on Wheels)
This is quite literally just a galley plus some storage space for firewood, tent, folding chairs, sleeping bags, etc. so it should be a pretty simple build for my first trailer. It is also very small and light.
*(Stick figure for scale added by my young son, it was too cute to crop out!)
It is going on a 48" x 40" Harbor Freight Trailer kit. The shell will be 5' long, 4' wide (so will overlap the tires just a bit, and thus have small wheel wells inside, but not much.) Both front and back radiuses(eses) are 24" Galley in the rear, a top loading platform in front for sleeping bags, folding chairs and other light gear. The lower front compartment I plan to have a movable divider in and will probably usually carry firewood closer to the axle and personal effects (clothing, etc.) closer to the tongue. Body will be plywood, light stain, with darker stained trim. It won't be finished yet, but I hope to have the basic (wooden box stage) complete enough to take on a quick weekend trip to Palo Duro Canyon, July 1st-4th, so the big progress will be happening pretty quickly (Do finishing details EVER get done? In any case, sanding, staining, and poly will take a bit longer to complete...)
I pick up the trailer tomorrow after work and will likely spend the weekend assembling it and painting it. I plan to move the axle back just a little bit from where it appears to be in the assembly guide, but not sure how much yet. (They don't give good measurements as to where the axle is mounted. But it shouldn't be much, it is a REALLY small little trailer after all!)
Aside from that, I just want to say that looking through this forum has already helped me considerably in my planning. I've always been a tent camper, but I am seriously thinking about building a foamie next, even if only as a present to my parents and never use it myself :-) I'm looking forward to this build first though, and look forward to sharing the process with all of you
jjoelc
