Ok, the trip is over and I haven't even posted a "complete" pic yet. By complete I mean the state it was in when I started the trip; it is still a long way from complete. Here is how it looked when I got to the campground after 220 miles of interstate including 20 miles through an extremely intense thunderstorm complete with torrential rain:
- IMG_9006.JPG (107.61 KiB) Viewed 2046 times
- IMG_9007.JPG (95.26 KiB) Viewed 2046 times
But I should revert back to the building first. Before applying the molding I ran 2" strips of one-sided butyl tape over all the corners and seams. I got the tape at Home Depot - it was a huge 6" wide roll, which was way wider than I was looking for. I hacked off part of the roll on the band saw, but the cut was not very nice. You can see the black butyl peeking out from behind the molding in the pics. My plan was to trim it off with a utility knife, but I didn't have time before starting the trip, and it really bonded well during the trip (saw up to 101 degrees F on the car's display while sitting in traffic) - now it doesn't want to peel off! I spent a lot of time debating over what to use for molding on the exterior. I am definitely pro-metal, but due to a severe lack of time and not having easy access to a sheet metal shrinker I decided to go with the PVC molding from Home Depot. The stuff was pretty cheap, and after making relief cuts in the lower flange every 2" it followed the curve of the roof really well. Flat strips did a good job of covering the flat seams. I attached it all with stainless sheet metal screws - which were just as poor quality as the zinc ones I mentioned before. 1/2" EMT should not be harder than a screw - but the threads were going completely flat on these screws. I was still putting the molding on about 2 hours after my planned departure time, and so the last bits are really rough.
And now I should talk about the Plastex - I really liked it before it left the shop. I still like certain things about it - it has a nice, clean look, it follows the curved contour with no complaint, it is super easy to trim with a utility knife. But it is not a material I'd recommend. As Dave mentioned, the thermal expansion is a big issue. I had not found reviews by anyone who'd used it as a skin, merely people asking about using it. I guess I should have researched it deeper. As soon as I pulled it out into the full 95 degree day from my 80 degree shop it started bulging. The contact cement could not hold it, and most of that blistered apart. It is now very lumpy - which is pretty annoying to me. But, it held it's watertightness through highway speeds in torrential rain. I later camped in it one night during rain and there were no leaks... So, I guess I have to call it a success, though it's not ideal and I will not use it again.
You can see the lumps/wrinkles here. This photo is after about 500 miles of interstate travel:
- IMG_9075.JPG (113.75 KiB) Viewed 2046 times
It generated some conversation on the trip. Within 5 minutes of pulling in at the campground a couple of registered Tearjerkers had come by to check it out. At a gas station on the way a woman that had never heard of a teardrop before spent 5 minutes asking about it and where to buy one.
The project was a success, even with the Plastex issue. I needed to prove out to myself the idea of travelling with a teardrop. Part of this was seeing how the old Mercedes turbodiesel liked being a tow vehicle. It actually pulled very well, and has plenty of power to keep up with traffic. It's heavy enough to feel confident towing, too. I now have a test tear to figure out exactly how much space I need. And, I'm already designing revision B in my head...
