sitnfat wrote:I'm not the best wood worker in the world. Seems using two sheets would be simpler and faster.
KCStudly wrote:The trick is to separate the outer fibers and support them rigidly with out adding weight. Whether you feel the need for the insulation value or not (noise suppression, heat/cool/moisture barrier) the extruded foam board is ideally suited for separating thin plywood since it provides a broad gluing surface and is very resistant to compression when loads are dispersed (...by the plywood).
...and it is wrong to think about whether the trailer can stiffen the cabin. The cabin is such a deeper section than the trailer frame that once the box is unitized (i.e. the bulkheads are in and the roof goes on) it will be the cabin stiffening the trailer, not the other way around.
TPCE is 5 mm inner skin laminated to 1-1/2 XPS with minimal 2x2 cedar frame work and two (2) plies of 6oz epoxy/FG cloth outer skin. It is as rigid as H-E-double hockey sticks! Unitize your construction and all of the smaller light weight pieces will add strength to the assembly, not weigh it down.
Before adding the outer skin, with the inner skin fully finished and with the door (no window or hardware) my 9ft 8in long x 49-1/2 in tall walls weight 45 lbs each; i could lift and move them myself quite easily, but the were already very stiff at that point. A 3/4 inch thk piece of 4x8 fir ply weighs 44 lbs and is really quite floppy by comparison.
Build airplanes not tanks. Build your trailer and your cabin light, that way there is less load for the structure to have to deal with.
If you want your walls to be thicker than 3/4 inch, I say go foamie! ... or at least do a traditional stick frame and foam wall with 5mm (3/16 inch) underlay ply skins.
yrock87 wrote:according to google, plywood is R value of about 1.25 per inch, so a 1.5 inch ply wall would be about R 1.8. the XPS I used was an R of 5, plus 1/4 in of ply (1/8 on each side) gives us a nominal R 5.3.
my cabin will be temporarily permanently installed. it is more than strong enough to take on and off, in fact I just moved it across town on the trailer and then took it back off to finish work without the tires and tongue getting in the way. I don't plan on ever taking it off for any particular purpose, but I hate not having options, so it will be removable with a few bolts if needed. It really is amazing how strong these things are when you combine them together into a box frame. you take bend board and foam, and glue it together with some 1x1 framing (which also bends quite a bit) and you end up with a surprisingly stiff panel, then you box it together with 6 sides (and a curve or two) and you end up with an amazing stiff box. I guess that cardboard is the same principle. a little corrugated cardboard that is folded into a box and then taped is suddenly strong enough to stand on (on the corners if empty) or carry 50-80+ lbs.
dwgriff1 wrote:Take a hollow core door. Put it between two sawhorses and you can sit on it without it breaking, and the whole thing is very light weight.
I made a whole pile of "hollow core doors" shaped as necessary and I textured and painted the panels on the inside before assembly (I am basically lazy). I framed the walls with 3/4 framing with foam in the core (which makes it stronger).
The one downside is that it is relatively easy to punch holes in that thin skin, particularly in the process of backing the trailer. That short wheelbase can be like pushing a cat by the tail.
dave
