The drop in the wire going to the camper battery has a resistance that causes a drop, but as the battery charges, the drop becomes less as the current to the battery goes down. eventually, if given enough time, the camper battery will reach a full charge. As battery V goes up, the difference between alternator voltage and battery voltage goes down, as dV goes down, the current in the wire goes down, since the resistance is constant, the loss goes down. Battery voltage approaches alternator voltage (minus diode drop which was compensated for by the remote
madjack wrote:...I read the manual also and here is my problem...I know that you can run a 10ga wire from the alternator to the camper battery(did it for years onna 22'er I had). I had no isolator but simply unhooked the wire when stopped so...why do I want to use somehing that requires that I run a full sized battery cable all the way to the camper...isn't there some kind of isolator that I can put in the camper and just run that same 10 ga wire??? I don't want the expense of a full sized battery cable(20/30'worth) and its attendant routing problems...there has to be a simpler way such as I did on my old 22'camper...
GeorgeTelford wrote:Hi PaulI don't need to know! I use the Henry Ford principle in cases like this
So you dont know?
Nothing at all wrong with keeping it simple, as long as simple works well.
GeorgeTelford wrote:The voltage drop in the wire will always be there even when the ampage drops resistance is resistance. Later you say that the resistance is constant? in the wire it is, but overall the resistance of the battery changes internally as the state of charge changes, this is how the so called "automatic" chargers alter their output, the battery resistance !!
GeorgeTelford wrote:Leon, do you believe that a standard alternator fully charges the starter battery? Its just from what you write you apear to believe this.
Talked to them about a battery isolator and it will work but it will still mainly charge the starting battery. The second battery will charge but will take longer to charge do to the regulator think it is a load.
Hi Paul
I am impressed with your auto electricians, you will be amazed to know that they are the first and only auto-electricians in the world (so far) who have not got that wrong...
Users browsing this forum: No registered users and 36 guests
