KCStudly wrote:I don't recall specifically, but they were about quart sized, or maybe liter sized, probably the 36oz bottle. I used it for foam wall blank butt joints, and most everywhere wood was joined to foam (except for skinning). That included wall sill and door surround frame to wall foam, door foam to door frames, and all of my wall blocking that went into routed out pockets).
When you go through your second gallon of TB2 you will know that you are in to your build for the long haul!
Let's see: (2) large bottles of GG; cracked the seal on a third gallon of TB2 (but probably won't use it now that I'm not doing canvas for the outer skin); at least two caulk gun sized tubes of PLP (for the wall to floor joints... I have wood sills, but if you are gluing foam walls directly to your wooden floor then maybe use GG instead); probably 6-8 tubes (or more) of PL300 for laminating foam (lots more details of how that went in my build thread); at least 6 cans of GS; and now that I am skinning with FG I'm onto my 3rd gallon of epoxy (plus a quart here or there). There was also a gallon of 3M green contact adhesive (which I would not do again) and several tubs of light weight vinyl spackle.
While you're shopping, buy the big bulk size packages of sand paper; don't even waste your time with the little 4 sheet packs or multi-grit packs.
Okay, YMMV, but I'm just saying, these things are a major project no matter how you look at it, so you have to be prepared to spend more money than you probably would think on the "consumables".
VijayGupta wrote:How much Gorilla Glue to buy?
None. Hate the stuff.
rustytoolss wrote:VijayGupta wrote:How much Gorilla Glue to buy?
so what are you using ?
VijayGupta wrote:rustytoolss wrote:VijayGupta wrote:How much Gorilla Glue to buy?
Let's see the pros and cons of Gorilla (polyurethane) Glue vs. a Type-II PVA like Titebond III
Cons:
* Short shelf life
* Expensive (even more expensive if it cures in the bottle and you throw half of it away)
* Foams
* Extremely weak in thicker glue lines (need to have a very well-fitting joint)
* Stains the skin
* Repeated exposure can lead to sensitivity
* Longer clamp time
Pros
* Water resistant
* Longer open working time
Franklin International, who also make their own polyurethane glue, says this in their FAQ section of their web site:
How does Titebond III compare to polyurethane glues?
While polyurethane glues bond well to a variety of materials, Titebond III is superior in many ways. In addition to excellent water-resistance, it provides a stronger bond on wood-to-wood applications, doesn't foam and requires less clamp time. Titebond III has no health issues, doesn't require the use of gloves and cleans up with water. It is significantly less expensive than polyurethane glues and offers similar coverage rates.
rustytoolss wrote:VijayGupta wrote:rustytoolss wrote:VijayGupta wrote:How much Gorilla Glue to buy?
Cons:
* Short shelf life
* Foams
* Stains the skin
* Longer clamp time
Pros
* Water resistant
So does Titebond III glue foam to foam ?
rustytoolss wrote:So does Titebond III glue foam to foam ?
