I had about 4 hours for the trailer today.
I finally finished skinning the inside of the back hatch. To seal the deal, I added extra skin to hopefully stiffen the joint where the door is bent/contoured.
More hinges came in, so I made a run to the store for more screws and then installed the last three cupboard doors. Then I painted them and spot-painted elsewhere. More drawer pulls are on order. I ordered some make-shift little latches for the drawers too. They've got style - that's all I'm going to say.
I stained the countertop. I'll do at least one more coat later. And then several coats of thick polyurethane.
I finally cut the steel for reinforcing the tongue. I added the two square tube pieces on the sides and some flat bar on the bottom (so as not to interfere with the motorcycle tray). It's all about half welded now. This video about weight distribution and unstable trailers raised my eyebrows:
https://www.youtube.com/watch?v=SXQt-8SZYT8I also finally carved out the wood piece that will house the other USB ports and light switch on the interior of the front wall. That's about 3/4 done now.
I'm getting pretty close to making the bed - I think we're going to take it out on an easy trip in the next week - up a few miles of potholed road.
