- Camper side profile.jpg (144.7 KiB) Viewed 3862 times
- Inside camper.jpg (170.32 KiB) Viewed 3862 times
- Inside back of camper.jpg (166.13 KiB) Viewed 3862 times
I was just taking some interior pics so you could see the cabinets inside which were built with idea of structural strength in mind.
I have no other threads going about this by the way.
The lower cabinets and drawers are made with 3/4" plywood and screwed to the 3/4" plywood floor using LOTS of 'L' shaped framing fasteners. Upper cabinets are made of 1/4" plywood wherever possible and 1x facing, with special attention paid to gluing and fastening and making them as strong as possible.
All the cabinet backs were 1/4" plywood screwed into the wall with those metal self drilling anchors (glued in with gorilla glue) and also glued against the wall with adhesive caulk like polyseamseal or such.
Also, I hope the pictures show it, there are wall ledgers here and there to hold up the small upper cabinets and the bunk and also to put pegs into. The pegs see a lot of use from, towels, hats, clothes, you name it.
