Well I made it back from the maiden voyage in one piece. Everything went good other than the actual hunt
, the hunting sucked to be honest. Due to the full moon several nights the deer were feeding by moonlight. I jumped a couple but not soon enough to get a shot.
Overall the trip was a success as far as the CTC went and I learned quite a few things. Some were things I wasn't sure if I'd need and several I just haven't done yet.
Anyway I loaded up the trailer and she looked something like this.
gallery/image_page.php?album_id=4250&image_id=145667&display=popupand this
I ended up flipping the 2" drop hitch to keep the front of the trailer as close to level as possible. My truck did good pulling the load overall but a new TV is on the short list of future upgrades.The truck is a 2000 model with a somewhat tired 4.3L motor and 3.21 gears so she struggled some going up some inclines and was slow getting to speed from a stop.
I got to camp, unloaded and set up camp in less than a hour. My set up looked something like this.
My temporary shower set up consisted of this tankless water heater. Even though I had to ration water I still took two showers, washed dishes, made coffee etc etc all on about 15 gallons of water.
If anyone is contemplating such a unit as part of their build I highly recommend the unit. Its the Eco-Temp L5 model. It makes plenty of hot water and you can't go wrong with the price. I plan to make a semi-permanent mount for it on the CTC just above my water inlet on the front of the CTC. I just did the current version so that I'd have a way to shower this past week.
A DC to AC inverter will be in the very near future, I may actually use two separate inverters. One modified and one pure/true sine wave. Exterior lights mounted by the entrance door and ramp door will cut down on having to use laterns and make moving around outside easier. I never got around to installing my 12V/utility receptacles or my USB charging plugs so those will happen pretty quick.
Other improvements will follow like the fold up bed, mini fridge and a few others.
Martin
