MadMango wrote:It's moving right along. CEO always wins.
KCStudly wrote:My advice with the peel and stick is to go ahead and use a compatible trowelable adhesive as well. I have had bad luck with the peel and stick tiles lifting up with large temperature changes (on a plywood bench top in my uninsulated garage... once I used trowelable flooring adhesive to restick the tiles it has not been a problem).
SCwood wrote:Very nice! Maybe a thin layer of construction adhesive troweled on would work if the contact cement doesn't wind up working out
