hankaye wrote:firemansd19, Howdy;
Welcome to the forum!
I have a 6'X14' single axle but I upgraded the axle to a 5300# with electric brakes. The
axle is a standard leaf spring that way I can flip the axle should I need the extra clearance
also the 7 way plug gives me the options of being able to charge the trailer's "house" battery(s),
through a converter should I choose to install one and I can add circuitry for back-up lights
should I, again, choose to. Options that you can discuss with the dealership if you go that way
or to consider should you buy a used one from C/L or some other source. Any way each is like
an empty canvas just waiting for the artist ...
hank
Picked mine up in Salt Lake City, Ut. drove to West Yellowstone, Mt. camped
for a week in it then drove home to the SW desert of N.M. Never knew it was
there unless I looked in the rearview mirror. My tow vehicle is a F-250 SD 4X4
which I use to move my 5th wheel (home sweet 5th wheel),whenever I decide
to relocate. What your tow vehicle is helps greatly to determine how the ride is ...
hank
PaulzOx wrote:Firemansd19,
Sounds like you have enough tow vehicle for almost any size trailer you want. If you don't have a storage issues I recommend going with the bigger size.
PaulzOx
Padilen wrote:7x7x14 singles were not available. At least not on a lot, might have been special order. I didn't want a 14'. I looked at a 7X14 tandem and thought it was huge. At the time I had lesser of a TV so I was happy with the 7x7x12, single. But now I have a bigger TV and different ideas. A 7x7x14 would be nice
Looking to see your CTC!
