Pmullen503 wrote:You can use hot melt glue to glue blocks with hooks the inside of the door pieces to allow you to pull them into place with straps while the epoxy sets up. Later you can just pop them off or use some alcohol to loosen the blocks if you get carried away with the hot melt.
friz wrote:I got a case of Canadian trailer spacers in the mail today.
Sent from my Altair 8800 using Tapatalk
justlisawv wrote:This is just gorgeous.
