Venom wrote:Hello. Been browsing for quite awhile, finally joined the conversation. Just starting my 1st build and have a question about floor insulation. I see most everyone sandwiching the insulation between 2 pcs of ply for the floor. However, has anyone skinned the bottom, filled the frame with insulation and just used one sheet of ply on top? My purpose is to utilize every inch of space possible, lighten the load just a bit and reduce the height just slightly. Pro's/con's? Your thoughts are welcome. Thanks
QueticoBill wrote:Michael - I looked at your build thread and I didn't see where the foil wrapped celotex was. Under the 5/8" ply? Adhered with epoxy? Between frame or continuous over frame?
Thanks!
