That's a great start for me and now as I posted on another posting, try to figure out material that's good to site on and great to sleep on.
yycwrangler wrote:Icon
I think were both in the same arena for builds. The only difference for me is that I want to make two sitting areas across from each other with a table in between. When the table is removed, the bed slides into place. Originally I was going to have both seating areas slide to make a bed 70 (well 69.25")" long platform (I'm 5'8" and my wife is 5'5" so we can sleep across the width of the trailer which is 69.25" on the inside). But if the seats area 24" deep, then only one of the seats needs to slide into the middle to make the bed foundation. (each seat is 24" deep X2 for a total of 48". Therefore the sliding part on has to be 21" (24+24+21"=69")which can be accomplished with one siding seat.
Hope that makes sense
Al
Iconfabul8 wrote:yycwrangler wrote:Icon
Al
Makes perfect sense. You could even do away with legs on the sliding part, just make it rest on the opposite side. You could even forget the slider and do like they do in campers and have the table drop across the gap.
yycwrangler wrote:Yup me again
Trying to do as much pre work before the trailer shows up late March. Today I'm working on a dining area that will pull out to a couch
http://vandogtraveller.com/expanding-bed-for-van/
I'm trying to calculate the depth, and height of a standard dinette frame. I'm thinking about 28" deep about 20" tall including the cushions that you sit on. And length will be no problem. Has anyone built their own dining seats and if so am I in the ballpark for measurements. The other consideration is how tall a cushion should be that you place your back against.
Thoughts?
Cheers
Al
