Hey all, long time lurker, first time builder. Finally took the plunge, bought a trailer and officially started my build. I'm looking at building a 5'x9' (maybe 8.5') on the super duty HF trailer.
Days one and two - 2/26/2017
QueticoBill wrote:Study your wheel location and consider mounting them further back at least relative to the mass of the cabin. Better tracking and balance, easier backing, and better door placement. You might accomplish similar goals by only building forward, not rearward on the frame, and then extending tongue.
I don't like the moment connections of the short 1 x 4s fore and aft of each wheel. That but joint is prone to sag. No one way to solve. I'd probably try to get a member all the way across and piece the front to back members, but not only way.
KCStudly wrote:I would do all 1x4's. One each full width at the hatch "bumper", under the galley bulkhead, fore and aft of the fender wheel, and at the front wall. No need for 2x4's.
Then just add more 1x4's to block in and add stability to the xmbr's. Get a Kregg pocket hole jig if you don't have one already (or my preference is a biscuit/plate joiner... cuz then you don't have to worry about driving screws into screws later); no need for the fancy, complex, time consuming box joints.
The structural logic should not be like the building of the pyramids where you have to pile more weight on top of a solid base to hold the whole thing up. The structural logic should be that you are building a unit where the sum of the parts make up the total strength, more like building a wing or truss structure.
Think of it this way, your front wall and bulkhead span the trailer crosswise bearing (resting) on the solid trailer frame, and holding up the walls, These panels are all very deep cross section "beams" and can support a great deal of weight. Attach your floor with a solid joint and glue to the edge of your wall and the wall holds up the floor, not the other way around. Now the floor only needs to be strong enough to support its own weight and what little weight might land in that short span between the wall and the blocking over the main rail.
Think of the cabin as a monocoque structure, not a brick house.
Check out jseyfert3's build.
Users browsing this forum: smeerkees and 5 guests
