I kept a trailer balance worksheet (see Design Resources) while building my TTT, to track weight going fore or aft to keep tongue weight (or lack of) manageable, because a side view of my trailer looked like it was rear-heavy. It was. Especially since I had major heavy items like ice chests, water jug, A/C unit, and generator all located in my galley area. To counteract that weight, I intended to put a battery and electrical, maintenance, and miscellaneous storage in a large tongue box, which I eventually found (thanks again, Prem). With that box, loaded, I found my balance not yet optimal at 10-15% on the tongue, but just under 10%. I even used the front of my cabin to haul extra coolers and water jugs to add forward weight. So, when travelling, I used my old standby, a weight distributing hitch. I always have one ready to go on both my trucks. I won't leave home (intentionally) without one. I constantly have to explain why I really depend on them. A personal preference, but it makes me more confident that my trailer isn't going to come off the ball, or wig-wag going down the road (I tow my trailers slightly nose-up, contraventing standard practice). On my big trailers, I use it to help manage large loads, sometimes a little aft of ideal, and on the little trailer, it imparts a load to the tongue, a simulacrum for true tongue weight. I adapted the one I use for my big trailers, to work on my TTT, by using only one spring bar, instead of two (my trailer has a single drawbar, 3" square tubing x .1875 thick). Here are links to a discussions of why I trust them:http://www.tnttt.com/viewtopic.php?f=35&t=57723&hilit=+weight+distribution and here:http://www.tnttt.com/viewtopic.php?f=42&t=67947#p1196907 While I later moved some weight forward, and didn't load the trailer with the heaviest coolers and water jugs until reaching camp (I load them in the truck bed), finally achieving the magic balance ratio, I still trust the WD hitch to control downforce.IndyTom wrote:so far, I know that most of my weight is forward of my axle, but I have not started my galley yet. Will be interesting to see what that does to my balance.
flboy wrote:Wow, looks like you were lucky to walk away from that and also not involve other vehicles.
I just put the anti-sway on my load balancing hitch last week. It made a big improvement on crosswinds and as trucks pass by. I won't do it any other way going forward.
aggie79 wrote:I like the idea of Dexter's electronic sway control. It controls sway using a sensor to detect direction and then applying braking to the side of the trailer that necessary to bring the trailer back in line. I believe it is currently "dealer install only" so it wouldn't allow DIY installations although it wouldn't be too hard to install.
https://www.dexteraxle.com/products/actuation/sway-control
working on it wrote:I kept a trailer balance worksheet (see Design Resources) while building my TTT, to track weight going fore or aft to keep tongue weight (or lack of) manageable, because a side view of my trailer looked like it was rear-heavy. It was. Especially since I had major heavy items like ice chests, water jug, A/C unit, and generator all located in my galley area. To counteract that weight, I intended to put a battery and electrical, maintenance, and miscellaneous storage in a large tongue box, which I eventually found (thanks again, Prem). With that box, loaded, I found my balance not yet optimal at 10-15% on the tongue, but just under 10%. I even used the front of my cabin to haul extra coolers and water jugs to add forward weight. So, when travelling, I used my old standby, a weight distributing hitch. I always have one ready to go on both my trucks. I won't leave home (intentionally) without one. I constantly have to explain why I really depend on them. A personal preference, but it makes me more confident that my trailer isn't going to come off the ball, or wig-wag going down the road (I tow my trailers slightly nose-up, contraventing standard practice). On my big trailers, I use it to help manage large loads, sometimes a little aft of ideal, and on the little trailer, it imparts a load to the tongue, a simulacrum for true tongue weight. I adapted the one I use for my big trailers, to work on my TTT, by using only one spring bar, instead of two (my trailer has a single drawbar, 3" square tubing x .1875 thick). Here are links to a discussions of why I trust them:http://www.tnttt.com/viewtopic.php?f=35&t=57723&hilit=+weight+distribution and here:http://www.tnttt.com/viewtopic.php?f=42&t=67947#p1196907 While I later moved some weight forward, and didn't load the trailer with the heaviest coolers and water jugs until reaching camp (I load them in the truck bed), finally achieving the magic balance ratio, I still trust the WD hitch to control downforce.IndyTom wrote:so far, I know that most of my weight is forward of my axle, but I have not started my galley yet. Will be interesting to see what that does to my balance.
