My Build Thread - Introducing the Bungalette!!
Re: My Build Thread - Introducing the Bungalette!!
Postby aggie79 » Thu Feb 02, 2017 9:07 am
And I thought I had the longest build on the forum!
Keep up the good work! :applause: :thumbsup: :applause:
Postby IndyTom » Thu Feb 02, 2017 2:10 pm
Thanks Tom. It is really starting to come together.
Never trust a skinny cook
IndyTom
Images: 42
Postby IndyTom » Sun Feb 05, 2017 2:31 pm
Finally something that looks finished. Finally started putting up the paneling on the inside.
IndyTom
Images: 42
Postby aggie79 » Mon Feb 06, 2017 7:56 pm
Panelling looks great Tom!
Postby IndyTom » Mon Feb 06, 2017 10:50 pm
Thanks Tom. I am currently looking for a water based poly that has the same sort amber tint that an oil based varnish would give. I really want to come up with something at least sort of close to what I remember my childhood family room looking like. I just don't want to wait for an oil based finish to stop smelling like an oil based finish.
11 years or bust!
IndyTom
Images: 42
Postby troubleScottie » Tue Feb 07, 2017 12:29 pm
Question on your design. The original drawing had 2 swing out units at the rear for the kitchen.
How much does each unit weigh with/without expected items stored there?
How big does the hinge have to be to support each unit? How does the side wall have to be build to carry the weight?
Is the hinge over the trailer frame or beyond the end of the trailer?
Personal design has slide outs to expose cooking surface and frig lid. Anticipate 100# rated slide outs should carry the weight. Could go up to 150# or even 200# without much redesign.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Postby IndyTom » Wed Feb 08, 2017 10:26 pm
Michael, I am getting close to the place where I am going to start working on the galley in earnest, but I have to say I am having second thoughts about doing the swing outs the way I had originally planned. I have seem some designs that are much easier, and don't involve putting a hinge in the side wall.
On that has caught my attention is in this video: https://youtu.be/us8o8eNV9To look at the 4:40 mark for what I am talking about.
IndyTom
Images: 42
Postby IndyTom » Wed Mar 15, 2017 3:46 pm
The first section of the ceiling going in.
Sent from my SM-N900T using Tapatalk
IndyTom
Images: 42
Postby IndyTom » Wed Mar 15, 2017 4:05 pm
The ceiling is finally going in! Just need some warmer weather so the PL Premium Pro will cure faster.Image
IndyTom
Images: 42
Postby IndyTom » Wed Mar 15, 2017 4:08 pm
This is the framing that I put together for the roof vent. Figured it was easier in my shop than reaching in from the sides, while standing on a ladder.Image
IndyTom
Images: 42
Postby IndyTom » Mon Mar 27, 2017 3:18 pm
Finally have the inside walls and ceiling done. The wood scraps pinned to the ceiling are only temporary. They are just holding things in place until the glue dries. So glad to finally be at this point.
IndyTom
Images: 42
Postby S. Heisley » Mon Mar 27, 2017 5:32 pm
You're making good progress! :thumbsup:
Postby aggie79 » Thu Mar 30, 2017 12:16 pm
IndyTom wrote:I am currently looking for a water based poly that has the same sort amber tint that an oil based varnish would give. I really want to come up with something at least sort of close to what I remember my childhood family room looking like. I just don't want to wait for an oil based finish to stop smelling like an oil based finish.
11 years or bust!
Tom,
I used TransTint dye to "age" the cedar on my tongue box. It is quite a versatile product. I "hand-applied" the dye to stain the wood (after diluting it with water) and then applied epoxy and Emtech 9300. TransTint can be mixed directly into some water base finishes. You may want to try this with the water-base poly. (I'd experiment with a pint of the poly to make sure the two are compatible.)
Take care,
Postby IndyTom » Fri Dec 22, 2017 5:49 pm
So, I have not done a good job of keeping up with this build thread, but here is a massive update. Lots of pics.
Sent from my SM-G955U using Tapatalk
IndyTom
Images: 42
