Our first tiny trailer build.
Re: Our first tiny trailer build.
Postby KingAirNeal » Sun Mar 26, 2017 9:55 pm
KingAirNeal
Postby friz » Sun Mar 26, 2017 11:25 pm
Looks great in the pictures. You will be the only one that sees the flaws. Give it time and you will be overlooking them also.
Sent from my Altair 8800 using Tapatalk
The "Sin Bin"
150133
friz
Postby S. Heisley » Mon Mar 27, 2017 5:45 pm
Yes, now, I see the runs. I agree with you, though, when you write that you'll finish building the trailer and then go back and re-do the outside later. The advantage I see in doing that is that you will be able to get lots of advice on how to fix it; plus, you'll be able to use it in the meantime. Who knows? You may decide to go an entirely different way later on, with maybe fiberglass or aluminum sheeting; or, you may decide that it doesn't bother you that much. It's your trailer and your call. What's most important is to get out in the "wild"' and enjoy! :)
Postby KingAirNeal » Mon Mar 27, 2017 7:13 pm
S. Heisley wrote:Yes, now, I see the runs. I agree with you, though, when you write that you'll finish building the trailer and then go back and re-do the outside later. The advantage I see in doing that is that you will be able to get lots of advice on how to fix it; plus, you'll be able to use it in the meantime. Who knows? You may decide to go an entirely different way later on, with maybe fiberglass or aluminum sheeting; or, you may decide that it doesn't bother you that much. It's your trailer and your call. What's most important is to get out in the "wild"' and enjoy! :)
Very true. We might put on a wrap at some point... who knows.
KingAirNeal
Postby KingAirNeal » Sat Apr 01, 2017 11:02 pm
Doors and window are in, rear doors are on, lots of small tasks getting done.
KingAirNeal
Postby ELM » Sun Apr 02, 2017 8:58 am
It's coming together and it looks great. :thumbsup:
My Build journal. viewtopic.php?f=50&t=65395
ELM
Images: 176
Postby KingAirNeal » Sun Apr 02, 2017 11:25 pm
DONE!!!!! Well, just about.
Interior trim, shelves/cabinet and rear door seals. And a little caulking here and there.
Going for inspection and registration Tuesday hopefully!
KingAirNeal
Postby friz » Mon Apr 03, 2017 11:15 am
Awesome camper! Time to load it up and see the world close up. Probably like you I have covered a lot of ground by air but have never had a chance to explore any of it. Airports are seldom built in the most scenic places and schedules don't allow for sight seeing. Yours is truly a one off. If I ever see it out and about, I will be sure to say hey.
The "Sin Bin"
150133
friz
Postby KingAirNeal » Mon Apr 03, 2017 3:31 pm
friz wrote:Awesome camper! Time to load it up and see the world close up. Probably like you I have covered a lot of ground by air but have never had a chance to explore any of it. Airports are seldom built in the most scenic places and schedules don't allow for sight seeing. Yours is truly a one off. If I ever see it out and about, I will be sure to say hey.
Thanks Friz. I hope perhaps we can make a point to meet up somewhere, someday. I want to drool on your piece of art!
KingAirNeal
Postby KingAirNeal » Mon Apr 03, 2017 3:32 pm
Well, got the movement permit to take it to DMV for inspection and registration tomorrow. Took it to the scales today. 1220 empty, 180 tongue weight! Trailers beautifully!!!!!
KingAirNeal
Postby KingAirNeal » Mon Apr 03, 2017 4:23 pm
KingAirNeal
Postby S. Heisley » Mon Apr 03, 2017 7:45 pm
It looks good to me! Good luck on the inspection tomorrow. :)
Postby pchast » Mon Apr 03, 2017 8:46 pm
pchast
Images: 97
Postby KingAirNeal » Tue Apr 04, 2017 12:02 pm
Inspection passed, and all registered!!!! Woohoo!
KingAirNeal
Postby ELM » Tue Apr 04, 2017 2:13 pm
That's great :thumbsup: When's your first camping trip.
ELM
Images: 176
