Industry's smallest all-in-one 45 Amp distribution panel/converter system.
Available with exclusive built-in Inteli-Power Converter...
"The most reliable converter in the RV Industry."
The AC distribution Panel is rated for 120 VAC @ 30 Amps
with up to 7 branch circuits.
The DC section has 12 branch fuse holders, two wired to
accommodate 30 Amp fuses, ten more with a maximum rating
up to 20 Amps each. All wire tail connections.
Exclusive hot buss and DC disconnect tie in.
Reverse battery blown fuse indicator.
Inteli-Power 4000 Mighty Mini models can recharge the battery to 90% of full charge.
BOOST Mode 14.4 Volts - Rapidly brings RV battery up to 90% of full charge.
NORMAL Mode 13.6 Volts - Safely completes the charge.
STORAGE Mode 13.2 Volts - Maintains charge with minimal gassing or water loss.
EQUALIZATION Mode 14.4 Volts - Every 21 hours for a period of 15 minutes prevents battery stratification & sulfation - the leading cause of battery failure.
The Grape Solar 265-Watt Polycrystalline PV Solar Panel uses high efficiency solar cells (approximately 19%) made from quality silicon material for high module conversion efficiency, long term output stability, and reliability. Virtually maintenance free. High transmittance, low iron tempered glass for durability and enhanced impact resistance.
Positive power tolerance (0 to +5-Watt)
Anti-reflective and anti-soiling surface reduces power loss from dirt and dust
Outstanding performance in low-light irradiances environments
Certified to withstand high wind and snow loads
100% electroluminescence inspection ensures modules are defect free
Positive and negative leads equipped with MC4-comparable connectors
When charging 12-Volt battery systems with this panel, an MPPT charge controller must be used
tanukihimself wrote:This CT will be my home. I expect I will be somewhere with steady power eventually but boondocking sometimes as well. I don't foresee spending a lot of time indoors unless its to sleep so I just want a manageable electronics system that's not too complicated but that I can add on to if need be, the PD4045 sounds like a good start if it has everything in one spot.
What else would I need besides the PD4045?
