2manytoyz wrote:Very cool build looking foreword too seeing it progress.
Brian
Thanks
Brian
Dirtclod wrote:That looks really nice. I love the fact that you were able to get it smooth.
I may have to look into this vs aluminum.
KCStudly wrote:Still looking good.
If it suits you and you don't mind taking the time, another way to fix that "holiday" (the router boo boo) would be to route out a slightly larger area with cut lines running with the grain, then glue in a Dutchman patch of matching grain. You could take a small rectangular section all the way from the floor to the sill of the door. The vertical grain lines would mask the repair somewhat, likely to the point that it would be relatively unnoticeable. Just another option that someone recommended to me back when I had a similar mistake.
glenn201 wrote:do you have a link where you got them torsion axles from
DWT77 wrote:glenn201 wrote:do you have a link where you got them torsion axles from
When I purchased them this was the cheapest place I found them
https://www.etrailer.com/s.aspx?qry=tim ... iler_Axles
Users browsing this forum: Google [Bot] and 6 guests
