Lots of tips here
http://mountainsurvival.com/campingtips.html
Dee Bee
oklahomajewel wrote:Some thrifty and dual purpose ideas there! I especially like these..
3. Canning rings can be use to cook your eggs in for egg sandwiches. (Works well for English Muffins or Hamburger buns).
Ma3tt wrote:Home made fire pit using a propane tank.....
kirtsjc wrote:.... if I use a lid with the ring, how do I "unscrew' the egg from the ring ?
IndyTom wrote:Warpony,
I sprayed them with Pam....... no thumbs required
Sweeeeeeeet, I'd hate to strip the threads on my egg Rolling Eyes
kirtsjc wrote:Ma3tt wrote:Home made fire pit using a propane tank.....
I have access to hundreds of tanks of assorted sizes (pre-OPD)...
How long should I let the valve be open before removing it, and then how long after valve removal should I let the tank set?
Then, do I need to wash out the tank any special way before taking a torch to it?
Looks like I should plan on cutting over to the valve thread for the notch, right?
Any kind of rack inside, or just "dump it in 'der?"
Joanne wrote:Even after all that time you could smell the residual gas being displaced as I filled it with water. I know I'm stating the obvious, but you don't want to cut into a propane tank with residual gas in it.
