Primer for the canvas on your Foamie
Postby rustytoolss » Wed Jun 21, 2017 9:22 pm
For the primer coat to cover the canvas/TBII. Does it matter what brand to use ? Or is this a place to spend some extra $$ ?
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Primer for the canvas on your Foamie
Postby ghcoe » Wed Jun 21, 2017 9:33 pm
Not sure if it matters, but I have been using Glidden Gripper for all my priming needs.
George.
ghcoe
Postby rustytoolss » Wed Jun 21, 2017 10:32 pm
The paint I plan to use is Sherwin Williams HGTV High Gloss Interior/Exterior (paint and primer all in one) . Thought I should note that. I did not notice that it was an "all in one (paint/primer)" until now. I doubt that using a base primer would hurt anything. But unsure if it is needed. :thinking:
I did send a question to Sherwin Williams , to ask if painting a virgin surface should be base primed first???
rustytoolss
Postby GPW » Thu Jun 22, 2017 5:07 am
Rusty, probably depends on how much you want to fill your weave … we found about 3 coats of a “primer” ( we’ve been also using Gripper) with some very light sanding in between ( more dust and nit removal than “sanding” ) makes for a pretty smooth surface … same as we use on our Art panels …
Our new paint for the FS roof is also ( self-priming) ,but we still put 2 coats of Grripper first though … old habits …
Postby lthomas987 » Thu Jun 22, 2017 11:00 am
Gripper was cheaper than the exterior paint I was using for mine. So I went ahead and primed it with two coats to try and get some of the soaking up of paint into the fabric taken up by the primer.
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
Postby mikeschn » Thu Jun 22, 2017 5:53 pm
I really didn't bother to try to fill in the weave. I like the coarse texture...
Having said that, we used the aluminum paint... It filled it in a little, but not much...
A year later I had to touch up one side, and it's noticeably smoother than the other side. But we are not creating show piece cars here, just rough and ready campers, right!?
Images: 479
Postby GPW » Fri Jun 23, 2017 5:47 am
“ just rough and ready campers, right!? “ …. supposedly !! :roll:
Postby Callmaker » Fri Jun 23, 2017 2:19 pm
I am new to the forum, but just finished a foamie build. I used a mix of Gripper, latex caulk and light weight spackle, spread it on with a flexable bondo spreader. I did two coats with light sanding after each coat. I finished it with two coats of Glidden Premium Exterior paint in satin finish. It turned out really nice, looks more like fiberglass that canvas.
Anthony
Callmaker
Images: 281
Postby ghcoe » Fri Jun 23, 2017 5:22 pm
Callmaker wrote: Gripper, latex caulk and light weight spackle, spread it on with a flexable bondo spreader. Anthony
Foamie smoothie mix.
George.
ghcoe
Postby GPW » Sat Jun 24, 2017 4:51 am
Write that one down !!!
Postby ghcoe » Sat Jun 24, 2017 10:52 pm
George.
ghcoe
Postby GPW » Sun Jun 25, 2017 5:59 am
