hankaye wrote:jr9744, Howdy;
When you said,
"Also, i'll have to install these vertically because they are too wide to fit between my studs. They were meant to be horizontal. Any things I should watch out for while doing this? I noticed it had slits on the bottom which I assume is for water run off, but those will not be facing downward when I'm done."
You are correct about the slits being for water drainage. With them on the side water can and will become trapped
in the frame and will most likely end up creating corrosion damage and/or mold and even a leak into the cabin area.
The choice is yours.
hank
Padilen wrote:I saw windows that have, slits on horizontal and vertical. But little plastic plugs in those not used. Window mounted vertically would have horizontal holes unplugged, and vise versa. Might have been on an RnR trailer.
'Padilen wrote:I did not frame my inlets. Because they have flanges holes were cut by wall up rights. This allowed the flanges to go into an up right. I used butyl for sealing.
McDave wrote:Hey jr,
. One method for locating things that go through walls where you want them is to drill tiny pilot holes. So, you decided where the outlet is going from the outside. Hold that baby where you like it and either mark the mounting holes with a pen /marker if you can reach through the mounting holes to the side, then drill, or use a small drill bit to go through the holes and mark or drill through side. It may be tough to get the drill into a tight space like the power inlet if the cover interferes. I have used toothpicks with a dab o' paint to make marks before. You could also make templates then use those to mark or drill.
Remember the old saying, "Measure twice, then go have a smoke and a beer come back and measure again, and cut once." Works for me most of the time...
McDave
