First time builder, Modified/larger teardrop-eqse
Postby Aviatorbrew » Fri Aug 11, 2017 3:49 pm
I have always wanted a teardrop but I never liked the size of them, so I came up with a design that I feel will be functionable for my needs
I wanted to be able to stand up, have a taller door than the normal teardrop hatch and have a enrty area that didnt involve crawling over the bed, those were my main issues
my trailer is 64" wide and 12 ft long, galley in the back, full size mattrese, 13 gallon fresh water, sink, stove, ecotemp WH, LED lighting, solar charge, 110v shore power to use when availiable and a few other things
I already had an old travel trailer frame, so I didnt have to do much in that area, just some trimming and welding angle around the perimeter
ripped 2 x 4s for the walls, 1/4" project panel board interior, 1 1/2" thick foam, the same 1/4" on the outside, I am planning on getting metal roofing metal sheets, before the manufacture rolles it into the ribbed roof panels, there is a local place here that does that, the colors are backed on also, I just order the material in flat sheets
I had a bunch of reclaimed redwood, I cut it and planned it down, its full of knots, nail holes and defects but it really looks cool! the rustic look, everything is just clear coated, no staining
I will start posting picts,
Andy & Mandy's Luv Shack!
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Re: First time builder, Modified/larger teardrop-eqse
Postby crpngdth2001 » Fri Aug 11, 2017 3:54 pm
Sounds interesting, looking forward to pics
crpngdth2001
Postby Aviatorbrew » Fri Aug 11, 2017 4:43 pm
Thanks, its been alot of fun!
this was an existing travel trailer frame, I just had to do a little cutting and weld a 2 x 2 angle around the perimeter. its good and solid
sealed 3/4 OSB for the sub floor, propane and waterline mounted under the deck
I welded 2 x 2 x 6" angle to the perimeter frame, in each corner, this allows a good positive wall attachment in addition to the other attachments along the perimeter of the angle
laminated 2 x 4 for the front end post, biscuit jointed for strength
first wall framing, the trailer is taller in the front, then it slopes down towards the back
150340150339150338150337150336
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby Aviatorbrew » Fri Aug 11, 2017 4:54 pm
sidewalls are up, I sheated the walls and clearcoated them in the shop, flat on the floor, then took them out and stood them up
the 1/4" project panel from lowes has a really neat grain pattern, it worked well for the interior wall surface, I glued it and stapled it with a 1/4" crown stapler I will make seam caps from the reclaimed redwood
I connected the walls with pre fabbed roof sections, it made it really nice not having to try to staple ceiling sheeting overhead
the trailer is now enclosed, I had to put the regular mattress in the trailer before I could finish the interior sheeting
150341150342150343150344150345150346
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby Aviatorbrew » Fri Aug 11, 2017 7:08 pm
galley area
bed deck, plenty of storage below, lift up hatch lid
storage area above bed
storage cabinet above bed, reclaimed redwood
flooring and water tank
front storage cabinet, all redwood also
homemade rope cabinet door pulls
150348150347150349150350150351150352150353150354
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby GO_C_DAVE » Sat Aug 12, 2017 3:00 pm
Hey Man... that's not a teardrop. It's a Condo! Bring it on by to Henry Cowell park next month.I would love to see it! It looks awsome :thumbsup: :thumbsup: :thumbsup: I like the fact that you are repurposing redwood! Gotta see it!!!
I can build that !!!!
GO_C_DAVE
Postby Aviatorbrew » Sat Aug 12, 2017 7:16 pm
thanks man,
I am not sure if I will have it done by then, I basicly have 5 weeks left, I will be do my best to have it done by then, we were planning on coming up for the day if it isn't complete, I am looking forward to seeing the other trailers and all of the creativity in there design
I am trying to get the wiring finished up so that I can start working on the galley, insulation and exterior sub sheeting
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby Aviatorbrew » Mon Aug 14, 2017 7:21 pm
not much progress this weekend, just working on the wiring, I hope to get the 12v wiring done this week :D
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby Aviatorbrew » Sun Aug 20, 2017 12:01 pm
its alive! i was able to complete the 12v wiring and hooked up a test battery, lights, lights and more lights!
dome led lights, they give off plenty of light
150561
white and blue led accent lighting
150562
150560
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Re: First time builder, Modified/larger teardrop-esqe
Postby Aviatorbrew » Sat Aug 26, 2017 12:25 pm
Not much progress today
worked on some cabinetry, finished up some plumbing, a little work on the galley rear wall, did a little bit of electrical work
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby Aviatorbrew » Sun Feb 04, 2018 8:36 pm
I havn'[t posted lately becuase of slow progress and life but I finally got back at it and the end is finally in sight, I need to use it in a couple of weeks, it will not be 100% complete but it will be usable
152837
152836
152835
64" x 12' standie,
Cheyenne Wyoming
2018 4 runner
Aviatorbrew
Images: 25
Postby HarleyCamper » Wed Feb 07, 2018 12:52 am
Looks spacious! Any HOA associated with that condo? :?
HarleyCamper
Users browsing this forum: No registered users and 48 guests
