hey Don I like your canopy led lights. What Kind and where from. Did they provide a channel and how did you affix it to the C.T ? Is there a dimmer switch?
Thanks!
Tommy B wrote:ok. pop in at 5pm with wife on the way home. Thanks!
flboy wrote:This should do it. New aluminum bus bar, coated with battery terminal spray. That should protect and prevent corrosion. I was getting 5A and 18v in the tree filtered light with partial shade. I think that corrosion was hurting the efficiency for sure and eventually would have failed totally.
I'll probably will get 30A or more now depending on battery needs in the direct sun. I have seen >30A before... but mostly ~15 A to 20A because the state of charge is usually pretty good. Running the fridge and etc. overnight doesn't really hit the 345aH (172aH useful) battery bank too hard.
Going to clean the roof and panels this afternoon. It has been a year already, time to inspect seals and etc..
