I need to look into this carbon nano thing, and maybe a flux capacitor to go with it.
low277 wrote:Back in the 19990s and early 2000s the company I work for partnered with Suzuki on a couple of items. They built generators with our name on them. The generator guy at the time claimed that there was only one or two of the actual generator head part in Japan and that all the big names used the same head and attached it to their engine, frame and packaging.
Not sure if this is true or not. I've owned a 1980s vintage John Deere 1800 watt with a Kawasaki engine and a Yamaha EF2000. Both good units. I would like to hear from anyone with a Generac like the one in the first post?
Bill n Robi wrote:So we are prepping for a 18 day off road/boon dock trip. Pulled the generator out of the shed where it has set since September of last year. Hooked it into the mount, OMG it took two pulls to start it..... and a slight adjustment to the mixture since it was set for 8000 feet.
Synth oil still as good as the day it was changed, day after after the break in run two years ago. No stale fuel, no carbon build up, no clogged spark arrester.
You can't go wrong with a propane conversion.
Users browsing this forum: Bing [Bot], steve cowan, swoody126 and 1 guest
