BobR wrote:The problem with reducing tire pressure is two fold. One, the reduction in stiffness of the sidewall reduces the load capacity of the tire. Two, it makes the tire run hotter from increased friction at the footprint and the flexing of the sidewall.
The best way to address the bounce issue is to make sure that the sring rate is appropriate for the weight of the trailer and to add shock absorbers to reduce spring rebound.
Just my two cents worth...
BobR wrote:The best way to address the bounce issue is to make sure that the spring rate is appropriate for the weight of the trailer and to add shock absorbers to reduce spring rebound.
BobR wrote:The problem with reducing tire pressure is two fold. One, the reduction in stiffness of the sidewall reduces the load capacity of the tire. Two, it makes the tire run hotter from increased friction at the footprint and the flexing of the sidewall. If you want to know what this can cause, just search for Ford Explorer and Firestone tire roll-over accidents. Tires that are run at highway speeds need to be properly inflated, period.
Artificer wrote:If I remember correctly, the Explorer rollover problem was that with higher pressures, the Explorer would tend to roll over during cornering. Ford lowered the pressure (26psi?) to increase road adhesion, but that brought to light manufacturing problems with the tires resulting in blowouts. Jacked up tall vehicles being driven like cars is a bad design.
