Dee Bee wrote:The HF trailer I looked at has a bolt pattern of 545, 5 bolts spread 4 1/2 inches.
Grant wrote:The 5 on 4-1/2" bolt circle is standard trailer stuff, and almost any 13", 14", or 15" trailer wheel with that bolt pattern will fit the hub. HOWEVER - the critical measurement with regards to the HF frame will be the BACKSPACE of the wheel and the sidewall bulge of the tire you choose for that wheel. There is NOT very much room between the sidewall and the frame on the original HF 12" wheel/tire, and most other wheels have more backspace to them and the larger tires usually have more sidewall bulge.
Users browsing this forum: Google [Bot] and 25 guests
