bobhenry wrote:Well here are some pics as promised....
I know you are going to tell me the joist hanger support is on upside down but when the weight of the walls outboard bears on the frame rail the inboard end will lift and the hanger is there to transfer the lift to the second member.
Here are some of the reinforcing plates to join the out board hips for the pooch out.
The outboard plates to join the 4x4's to the pooch out
partially coated with the asphaultic fence post treatment
all done !
As I said in the post above.....It's ready for the 4" foil faced polyisocyanurate sheets. These will be cut to fit in the voids between the 4x4's blanks and then the plywood sub floor will be installed. All this done I can start setting walls.
Users browsing this forum: No registered users and 25 guests
