ChrisW wrote:Thank you both for the advice. Both of your trailers look great!
Andrew, I have bare plywood and thought it would be a good base coat to help seal the wood from any potential rot as I saw that a few people on here had used it. Originally, my plan was just the primer and paint, which of course would be easier. Do you (or anyone) know if there is really much benefit to using the mix under primer and paint? It will mostly be stored inside and hopefully only see rain or snow rarely (because I'm sure it will only sunny when I camp and travel with it )
Andrew Herrick wrote:ChrisW wrote:...I have bare plywood and thought it would be a good base coat to help seal the wood from any potential rot as I saw that a few people on here had used it. Originally, my plan was just the primer and paint, which of course would be easier. Do you (or anyone) know if there is really much benefit to using the mix under primer and paint? ...
Whether or not your plywood would benefit from extra waterproofing depends on the quality of the plywood....The main issue I see with using "the mix" is that painting over polyurethane can be difficult. Sanding/etching the polyurethane and using an exterior oil-based primer is an absolute must.
