GPW wrote:A Capacitor is basically like a Bucket for electricity , you can fill it up or empty it quickly , and it doesn’t “use” electricity, only stores it … For starting assist , when the voltage drops during the start, the ”bucket” empties out quickly to help … just like a booster battery , sorta’ ...
Heavy_Fuel wrote:GPW wrote:A Capacitor is basically like a Bucket for electricity , you can fill it up or empty it quickly , and it doesn’t “use” electricity, only stores it … For starting assist , when the voltage drops during the start, the ”bucket” empties out quickly to help … just like a booster battery , sorta’ ...
I thought the capacitor had something to do with power factors, phase angles, motor winding inductance, and all that magical AC stuff, which I never fully understood?
Socal Tom wrote: The info I can find says that a fridge needs something like 700 to 1000 watts per day, that's about 30 to 40 watts per hour. My convertor can supply up to 45 watts per hour so as long as the generator runs 24 hours I can power the fridge and not lose battery power
whateverJohn61CT wrote:Socal Tom wrote: The info I can find says that a fridge needs something like 700 to 1000 watts per day, that's about 30 to 40 watts per hour. My convertor can supply up to 45 watts per hour so as long as the generator runs 24 hours I can power the fridge and not lose battery power
Watts per day, watts per hour is not meaningful.
Maybe you mean watt-hours?
For people more oriented around running loads from batteries rather than long genny runs, amp-hour at 12V are commonly used.
As an example for illustration
An efficient 12V fridge can use as little as 20AH per 24 hours. On freezer settings in hot weather, can get over 40AH per day.
That converts to 200-500 wH per day.
Users browsing this forum: Google [Bot] and 8 guests
