NotJammer wrote:Get a screen door. It was an option for me. A good one.
I wish I had specified steel wheels as I think they are stronger and reparable with a hammer.
Any insulation options? I wanted closed cell foam underneath but they said no. I later found that to be a lie. Too late.
I went for drop jacks as they seemed to give more ground clearance. Not ideal, but nothing is.
Bogey wheels are an idea. As is added height. Mine is low.
Go over all options a bunch of times. I think they save money.
Padilen wrote:I'd not plan on a portable AC.
PrecisionLook612 wrote:Padilen wrote:I'd not plan on a portable AC.
Vs a rooftop unit or even a window unit? Do the portable ones not work even with proper venting?
I will look into the screen door and the spare as well.
McDave wrote:...There has been a lot of "discussion" as well as debate about Air Conditioning. If budget is not a concern, then you don't need to re-invent the wheel. Rooftop A/C's are proven, tried and true, purpose built machines that are located in the proper place. Every other type, with the possible exception of mini-splits are a compromise solution. You have to be willing to accept trade offs in order to save a couple hundred dollars. Your original question indicates that you want to do this once and do it right. Don't step over dollars to pick up dimes. You mentioned having the rooftop A/C framing installed, I would suggest planning/adding an additional frame so you can have a rooftop vent AND rooftop A/C. If you are planning a bathroom/shower that would be a good place to vent, or above stove top. Try to keep weight and balance in mind as you are planning so that permanent installs like tanks and A/C's etc. are somewhat balanced when trailer is empty. Here is a tool that will help.
https://www.engineersedge.com/calculato ... alance.htm
Just my opinion. McDave
Iconfabul8 wrote:The other thing you will experience with a rooftop unit in a small space,is problems getting rid of the humidity. Smaller units run long enough to condition the air(remove Agua) large ones turn off before they have a chance to get the job done. Might be something to consider depending on where you live.
Users browsing this forum: Carolina6238, foxontherun and 17 guests
