Au contraire, McDave, your statement above is the only contentious opinion in this thread; on my part, all my statements were from personal experience with the types of air conditioning equipment (and I have personal experience with "swamp coolers", as well), not "feelings", "I've heards", or "Old Wives Tales". I was there to witness my grandfather's repeated bad experiences with the portable units, even sleeping in a bedroom where one unit was operating, so that's not an "I've heard", either. And, perhaps I, and maybe flboy, both living in hotter and more humid climes may have more personal experience using A/C than some others, so there really can be no debate, just statements backed by experience. In addition, I have stated, in this thread and many others, that I really like the window units, and perhaps I am more accustomed to the background noise produced by them, and regard that noise as a soothing "white noise", that lulls me to sleep, as it did when I was a child. And now, having been preached to by a "big boy", I'll go back to sleep....McDave wrote:...I didn't intend to turn this into yet another debate over Air Conditioners where we air our "feelings" and defend our decisions at all cost to include "I've heard"s and other Old Wives Tales about removing heat and not humidity...So, you can put that window shaker inside the cabin with you and tell yourself it is quieter than having all that machinery located outside, and that somehow 6000 or 8000 btu is equal to or greater than 13,500 btu, and that after you have done enough mods to deal with the drain water issues and using precious limited floor space, that it was all worth it, or you can do what the big boys do.... McDave
CoventryKid wrote:Haven't had a problem with our portable a/c but then living on the "wet" coast of Canada, we don't have to use it that often. But it worked fine for us last year in the 100+ F heat in Boston and Washington, DC.
I like that portables plug into 15A circuit, and as you say, one 5" hole in the side of the trailer. One downside for a small CTC is where to store it.
Just our experience.
Hope thus helps.
Iconfabul8 wrote:You might check our Hader's method. It is pretty stealthy.
viewtopic.php?f=42&t=67319&start=105
Hope thus helps.
PrecisionLook612 wrote:I appreciate the responses and actually don't mind the a/c debate going on.
I live in AZ but don't plan to camp much where I need A/C. I prefer boondocking to get away from the noise of generators in campgrounds and I don't want to be ruining my own peace and quiet. On occasion though there might be a time we are taking a road trip and we need to camp a night in the heat where A/C is a necessity on the way to cooler temps or extending kayak season at a desert lake. For me picking which a/c isn't a matter of cost as I want to do it right the first time but a matter of convenience and keeping clean lines to the trailer. The rooftop is a no brainer as it works the best but the cons to me are the power requirements and the potential for short cycling. I really only want to have a 2000 watt honda for my generator. I also want to run a good powered fan but If I can get two holes in the roof that is no longer an issue. The window unit solves both those issues as it takes much less power to be running and will run longer to keep things dry but I don't want a window unit hanging out the side or off the front of the trailer. The portable is definitely a compromise but does keep the lines of the trailer clean and can be removed when not needed.
I think for now my best option is to go for two holes in the roof and cross the A/C bridge when I come to it. Worst case I end up with two fans on the roof!
Thank you. The 15 amp circuit is a huge plus. What portable unit are you running?
