John61CT wrote:"Foil" as in mylar, reflectix, only works as the outermost layer, facing out with dead air in front, to prevent radiant heat from entering.
Any other use is a waste.
McDave wrote:John61 is correct. However, this may be an alternative. Polyiso hasn't been around forever, but cold has. I've seen a lot of crawl spaces insulated this way. I'd be willing to bet the older airstreams and like have a similar insulation. Here is an exploded view of a mobile home.
McDave
You may want to look at concrete blankets as well. Here is an example.
http://www.strongarmstore.com/shop/tarp ... gIM4_D_BwE
Yes, they do, but many DIYers just follow tips from fellow amateurs, info gathered from YouTubers, bloggers, maybe the guy at HD; a bit of googling, sticking to authoritative building trade insulation references, even data sheets from the materials' manufacturers will yield better information.sodatrain wrote:it's just that nearly everyone seems to do it!!John61CT wrote:"Foil" as in mylar, reflectix, only works as the outermost layer, facing out with dead air in front, to prevent radiant heat from entering.
John61CT wrote:Yes, they do, but many DIYers just follow tips from fellow amateurs, info gathered from YouTubers, bloggers, maybe the guy at HD; a bit of googling, sticking to authoritative building trade insulation references, even data sheets from the materials' manufacturers will yield better information.sodatrain wrote:it's just that nearly everyone seems to do it!!John61CT wrote:"Foil" as in mylar, reflectix, only works as the outermost layer, facing out with dead air in front, to prevent radiant heat from entering.
Using plain but robust plastic sheeting creates a much more effective and cheaper vapor barrier, since the reflective materials are usually both flimsy and more costly.
