Using Aluminum Composite Panels
Finishes, paints and coatings
Re: Using Aluminum Composite Panels
Postby aggie79 » Mon Nov 21, 2016 4:57 pm
[quote="Andrew HerrickDo you know how thick the alunimum facing is? I'm curious about the product, too, but I'm wondering how it will hold up years down the line ... can it be acid washed seasonally? :thinking:[/quote]
I guess I'm curious as to why anyone would want to acid wash aluminum annually? Maybe it is a corrosion issue from road salts or something.
The aluminum sheeting on my teardrop is anodized. I do apply a coat of carnuba wax annually to help wash off tree sap and bird droppings but that is about all the maintenance I do.
Postby aggie79 » Mon Nov 21, 2016 4:59 pm
bobwhite215 wrote:I bonded my first piece if ACM to the camper last night. Just a small piece for the rear bumper area. Glued it to plywood with Loctite PL Premium. The 3x version, not the 8x Fastgrab. Played with the 8x a little and didn't like it. The 3x is much easier to work with. Sanded the back of the ACM before applying the adhesive, and clamped it in place. I don't think I could tear it apart without destroying something. I think this is what I'm going to use for the rest of the project.
Sent from my XT1080 using Tapatalk
Looks great! I'll be following your ACM experiences and your build closely. Thank you for posting this.
Postby bobwhite215 » Fri Dec 02, 2016 8:28 pm
Things are moving along, and the ACM is working great.
Cut the basic wall out of 3/4 plywood
Roughed up the backside of the ACM with some 150 grit sandpaper to help the adhesive have something to grab onto
Loctite Premium PL adhesive
Laid the glued up wall down on the ACM, walked all over the backside to spread out the adhesive, and "clamped" with a bunch of cinder blocks
Let dry for 24 hours
After it dried, flipped the wall over onto the worktable to trim the edges. Moved it outside because cutting ACM can get messy.
Flush trim bit on the router
Router cuts extremely well thru the ACM. Thought I might need to pretrim closer to the final shape, but no need.
And there is the final wall mounted to the floor.
bobwhite215
Postby rruff » Sun Feb 12, 2017 9:18 pm
bobwhite215 wrote:Things are moving along, and the ACM is working great.
Any updates on this build?
rruff
Postby bobwhite215 » Sat Jan 06, 2018 8:33 pm
For anybody who might be interested, sorry I have not posted in this thread for awhile. I've been postinbb in my build journal at the following link.
http://tnttt.com/viewtopic.php?t=67211
Sent from my SM-T817V using Tapatalk
bobwhite215
Return to Skinning secrets
Users browsing this forum: Google [Bot] and 17 guests
