This is about as simple as it gets. 50w panel from eBay with the controller on the back. Direct to battery under camper. I set down my cocktail every once in a while to reposition the panels.
Sent from my SM-G930V using Tapatalk
Going by our tent camping we hardly ever camp in the same place more than two nights, then move to another area, might be a hour drive or 6 hours. That would give time to catch more sun. Would I be better of just charging with the TV? I was planning on putting in a 7 pin connector.
KTM_Guy wrote:Have the panels got better with less that full sun and shadows?
John61CT wrote:KTM_Guy wrote:Have the panels got better with less that full sun and shadows?
Even if they did, not enough that their mounting could get away with actually causing any!
Let's say in the old days a leaf, twig or bit of bitd poop caused total production to fall by 90%.
And then recent changes means with the same partial shading it drops by 75%.
Yes improved.
But you still want to avoid the shading.
Engineering a tiltable mount can double output, now that would be worth it!
KTM_Guy wrote:My thinking was if 1/4 of the panel was in full shade you would still be getting full output on the 3/4 still in full sun light.
KTM_Guy wrote:How durable are the thin bendable panels? Could it be stored under the mattress? Probably a 6"-8" memory foam. Maybe a piece of cardboard or 1/8" plywood to help protect it? Then pull it out when needed and plan on spending some time in the sun.
KTM_Guy wrote:[
I guess I don't understand solar at all. My thinking was if 1/4 of the panel was in full shade you would still be getting full output on the 3/4 still in full sun light.
What this guy says. My 50w panel has to be in direct sun to give me enough voltage to charge my battery. If the sun drops behind a cloud, i lose almost all electrical pressure. The angle of my panel also makes a huge difference.Socal Tom wrote:KTM_Guy wrote:[
A solar panels, is a collection of individual silicon cells that each make about 1/2 (.5) of a volt. However, a typical 12 volt panel will contain 36 cells wired in series to produce about 18 volts PEAK output. If you shade one of those cells you lose the voltage from that cell. So once you've lost about 6 cells out of the 36, the voltage has dropped to is too low to charge a battery effectively, that's assuming all the others are working at peak power, which only happens at noon during a full moon if you hold your tongue just right.
CaleyAnn wrote:Bruce, Thanks for posting this. I am one of those Newbies who knows basically nothing, but am trying to convert a very small cargo trailer so I have a place to sleep and seek refuge at night. A 12 volt system is a must for me. I do not want to fool around with a generator. I always have problems with those, and never have been able to figure out why they quit in order to get them fixed. They are expensive in the long run when you have to keep taking the generator in to a shop to get it going again.
Did anyone mention a good solar panel that can be had on Amazon. I haven't gone through this thread yet, but am hoping someone will suggest something before I go blind reading everything. :-) CaleyAnn
tony.latham wrote:
I've had good luck with Solar BLVD. Here's a folder that should meet your needs:
https://www.solarblvd.com/products/solar-cynergy-160-watt-foldable-12-volt-solar-panel-2/
It's a plug and play. Just hook it up to your battery.
Users browsing this forum: Google [Bot] and 6 guests
