S. Heisley wrote:Good job! And, don't worry about the doors. You probably just need better sealing tape/weather stripping or something like that. It looks like you're 99.5% done!
I like the faucet. I might look for one like it as I'm not all that fond of the one I am using now.
GPW wrote:Like Sharon said "Good Job “ !!! and it’s so CUTE too ...
amandacreiglow wrote:S. Heisley wrote:Good job! And, don't worry about the doors. You probably just need better sealing tape/weather stripping or something like that. It looks like you're 99.5% done!
Thanks!
But unfortunately, I’ve spent enough time and money trying all sorts of different weatherstripping to be pretty sure there’s nothing saving these doors. The design and execution was both off with them, I think. They look pretty bad anyway, though, so I can really only remake them better. :-) I’m heading down to Greenville today, where I’ll set up some tarps to protect myself from the rain, and will have enough time there to finish the rebuild on them. Already have the hardest part done, so should be doable... might even be able to manage openable windows!
I’m happy with the galley pump I got so far, although I wan’t happy having the shell out for it because of the way the opening was with the sink I bought. Here’s a link to it:
Mark 6 V PUMP, Galley self priming hand pump (MK 6) https://www.amazon.com/dp/B000FHDF3M/
amandacreiglow wrote:First morning coffee in the trailer. Everything works! Which is good, since I didn’t have a caffienation backup plan...
great place to look, but overpriced. Online marine suppliers will be cheaper for big ticket items even with delivery.S. Heisley wrote: I think I'll take a run over to West Marine
Sparksalot wrote:amandacreiglow wrote:First morning coffee in the trailer. Everything works! Which is good, since I didn’t have a caffienation backup plan...
Where did you find the stamped metal panels?
Don L. wrote:Hi,
Nice to see that you are out camping! I see that you are near Richmond, there aren't a lot of campgrounds open this time of year, glad you found one!
FYI, about leaking doors, I had a concern on mine so I put these- http://www.randgsupply.com/Warehouse/Do ... ipcaps.htm
over all of the windows and the door and have not had any issues. The water drips well clear of the openings. Even though I have a commercially made door and windows , water is not okay in my camper!
I screwed them to the PMF with some adhesive caulk to help hold them on and have not had any problems. The screws hold well enough and once the caulk dries they are on pretty good.
