Reattached with some contact cement, feels solid now.HarleyCamper wrote:I'm sure it's a common question, answered many times. I apologize for that. My searches did not render the question/answer I was seeking. I've decided to abandon the woody sides and skin in aluminum entirely. I want to seal the wood before skinning in aluminum. I know epoxy or CPES is a preferred method, but how about "the mix"? any success stories using it under aluminum? Being diluted, it should have decent penetration. If I do go with CPES, what options are there in filling the screw holes and plywood seams?
Unfortunately, my build has slowed due to my work schedule changing to overnight shift. Using the peel and stick tile produced mixed results already. On the front lip of the counter, the vertical pieces are beginning to fall off. I guess the adhesive isn't strong enough or too flexible for a vertical application. I will be trying some contact cement using the same pieces before I resort to plan C, whatever that may be.
pchast wrote:A little late now. With titebond, like other yellow glues, you can often reactivate the glue.
Just press down the bubble with a hot iron and a cloth..
Test it on a scrap First to adjust the heat so you don't melt the foam....
And keep the iron moving.
Harbor freight 9x12 ft drop cloth. I only needed 2 and had no seams.clamlamp wrote:Are you using home Depot canvas drop cloth?
Sent from my ONEPLUS A3000 using Tapatalk
