BlueRidgeSquatch wrote:So I'm trying to layout my 5x8 camper design in sketchup and I'm trying to figure out the best approach for the walls. I'm going with a more squared camper with 3/4" square tubing framing the camper. The reason for the metal frame is because I intend to haul kayaks (couple hundred lbs) and leave myself open to the option of an RTT if I ever have the desire, and the possibility of it going down rough roads. But I'm stuck on how I should approach doing the walls. I was considering going with a filon skin and i'm not really sure how thick of plywood backing I should go. I was thinking maybe 1/4" plywood on the exterior, then fill the 3/4" area where the tubing is with insulation. Is 1/4" overkill? I want to make sure its durable since I'll be loading kayaks on it (don't want slip and tear something up). Should I look at skinning it with aluminum? I'm not trying to break the bank, but don't want regrets. Also, what would everyone recommend for skinning the interior? I haven't seen 1/8" lauan anywhere in a 4x8 sheet around here (I'm in Staunton, Va). Is there something equivalent?
John61CT wrote:It isn't the rooftop weight with kayaks, so much as wind side loading and even lift at highway speeds.
I think some sort of metal framing is safer, but doesn't have to be too heavy if the side and maybe even vertical loading is well supported by the shell enclosure materials.
tony.latham wrote:I'm a big fan of 1/4" subfloor plywood. It's cheaper than 1/4" ACX and much better stuff. It'd look great inside. Not a fan of the luan plys. It's a generic term so you never know what you're really getting as far as glue and interior layers.
You could sheath over your steel tube with just .040 aluminum but it'd be easy to dent. (And you'd want to put something between the steel and the sheathing to keep it from dissimilar metal corrosion. There's probably a product out there but perhaps a good duct tape would work.)
I'd cover it with the subfloor ply and then the sheathing of choice. Fiberglassed and coated with Monstaliner would make for a durable finish.
