Ultra Tow stub torsion axles from Northern Tool
Postby Homebrewer25 » Thu Mar 15, 2018 11:48 am
Has anyone used these axles to build a TTT frame? Seems like a great way to build your own or customize a trailer.
ultratow stub axles.jpg (21.34 KiB) Viewed 1136 times
https://www.northerntool.com/shop/tools/product_200649004_200649004
Adding the complete hubs (item 572251 easy lube hubs) and a brake kit (7", item 21489) would make up a complete 2000 lb axle kit with brakes for around $360.
If anyone has used these I'd like to hear about your experience with them.
Or even if you just have an opinion on using these I'd like to hear it.
It's 5 o'clock somewhere ... time for a :beer:
Foam Ranger Build (postponed by COVID - resuming spring 2021): http://www.tnttt.com/viewtopic.php?f=50&t=70159
Homebrewer25
Images: 19
Re: Ultra Tow stub torsion axles from Northern Tool
Postby KCStudly » Sun Apr 22, 2018 11:35 am
They do not appear to have provisions for brake backing plates and in the Q&A section under the specs it says they are not compatible with electric brakes.
