Coleman Portable Shower - Modifications????
Postby Loader » Mon Jul 10, 2006 8:58 am
I know a couple people have purchased the Coleman battery operated portable shower Coleman Shower
I even remember reading someone had modified the shower head with a different type outlet. I can't seem to find that post now. If anyone has modifed this unit, or installed it, I would appreciate some pics.
I picked this unit up at my local BX, the price was right, figured it would be worth trying to use as a water pump.
Thanks
Earl & Kerry
"Loader"
Loader
Images: 245
Re: Coleman Portable Shower - Modifications????
Postby rampage » Mon Jul 10, 2006 9:53 am
Loader wrote:I know a couple people have purchased the Coleman battery operated portable shower Coleman Shower
Thanks
EZ did something like that and I think Ira did too.
"If you can't be a good example, then you'll just have to be a horrible warning"
rampage
Images: 5
Postby Loader » Mon Jul 10, 2006 10:45 am
Thanks Rampage, that help narrow the search down. I found it in Ira's topic about "Little Round Plastic Things..." :
http://tnttt.com/viewtopic.php?t=9246
fornesto did the modified version.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby EZ » Mon Jul 10, 2006 10:45 am
Earl,
I used a battery powered pump that I purchased off Ebay. I just cut the hose off as required and connected it to a faucet that I fabricated from a plastic plumbing fixture. It has a battery box that holds 4 D-calls and also a cigarette lighter adapter so it can be run off of either. The picture only really shows the battery box as the pump is submersible. The unit can be seen as posted by Fornesto at:
http://www.tnttt.com/viewtopic.php?t=7513&postdays=0&postorder=asc&start=15
It pumps well with plenty (too much) pressure. I just pinched off part of the hose to regulate. Works well for me (not much use yet) and for $20 I have dual-powered running water.
Ed
EZ
Images: 72
Postby Loader » Mon Jul 10, 2006 11:02 am
Ed,
Thank's a lot. Just what I was looking for.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Ira » Mon Jul 10, 2006 11:37 am
I decided to just use it as is, nestled in a hole, so I can pull it out to the side to use also as a shower. I think this makes for easier dishwashing too, more convenient than a fixed faucet.
But...
Ed, if it's connected to a faucet, is the faucet always on? Also, on your unit, can you lower the pressure on the unit itself?
And Earl, on the Coleman, there's "writing" on there that you can adjust the pressure, but nothing in the manual about it. Have you played with this at all? And have you given any thought how to mount the footswitch?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Loader » Mon Jul 10, 2006 11:54 am
Ira,
The only adjusting I found is on shower head itself. You rotate the the nozzle, and the stream changes from the inner to outer ring of holes. (Hope that makes sense).
As for mounting the base, haven't looked real close as to where to put it. You?
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Ira » Mon Jul 10, 2006 2:13 pm
Loader wrote:Ira,
I didn't even realize that about the pressure adjustment--I thought you had to play with the center screw there. I just thought it was weird that the manual didn't mention anything about adjusting the pressure.
I'm trying to come up with a base/power mounting solution where you use your finger, and not your foot. I was thinking about under the countertop, with the button facing down. (I don't want to drill a hole into the countertop just for this.)
It's just that the power base doesn't have any handy holes to just screw into for mounting. Like, we would need some kind of straps/bracket to mount it under-counter or on a side wall.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Loader » Mon Jul 10, 2006 2:29 pm
Ira wrote:I'm trying to come up with a base/power mounting solution where you use your finger, and not your foot. I was thinking about under the countertop, with the button facing down. (I don't want to drill a hole into the countertop just for this.)
Idea just came to me, I'll have to look at it closer when I get home, but what about cutting a hole just large enough for the switch in the counter, and install the base onto a shelf, bracket, or the like you attach to the under side of the counter? It would be some work, but it might be the result needed? :thinking:
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Ira » Mon Jul 10, 2006 2:35 pm
That's the thing, Earl--I don't want to cut a hole which would "marry" me to it forever. Know what I mean?
I would rather have it upside down on the underside of the counter. So if I ever want to ditch it for the Hot Water on Demand, I didn't commit a hole in the countertop for it.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Loader » Mon Jul 10, 2006 2:46 pm
Understand, no hole. I guess I'll be sitting on the pondering stool this evening trying to figure out where to mount the thing. Good thing there is a beer or 3 in the fridge.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Ira » Mon Jul 10, 2006 3:11 pm
Loader wrote:Good thing there is a beer or 3 in the fridge.
Ohhh...thanks for reminding me:
I gotta pickup a few.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby EZ » Mon Jul 10, 2006 3:12 pm
Ira, if you look at my pic you will see a pull-on switch (bilge pump switch?) from the boating supply place to turn on the water. Of course that required a hole and you don't want a hole. Hmmmmm.
Ed
EZ
Images: 72
Postby Ira » Mon Jul 10, 2006 3:20 pm
EZ wrote:Ira, if you look at my pic you will see a pull-on switch (bilge pump switch?) from the boating supply place to turn on the water. Of course that required a hole and you don't want a hole. Hmmmmm.
Ed
Oh--now I got you. I didn't look closely before--it's a facuet without a handle.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Elumia » Mon Jul 10, 2006 3:57 pm
mount a similar push pull switch under the cabinet so you can pull on and push off with your body if your hands are wet.
Elumia
Images: 15
Users browsing this forum: No registered users and 40 guests
