square drop foamie trailer build
Postby nemoskull » Sat Apr 22, 2017 1:22 am
so i have enough to start my build. this is a long term/full time trailer. so a few things are needed.
shower. inside.
toilet that can dump to rv dumps.
can cook. so stove or microwave indoors.
running water. cold and hot.
Solar power and inverter.
all built on a HF chassis. :D
nemoskull
Re: square drop foamie trailer build
Postby noseoil » Sat Apr 22, 2017 4:57 pm
Must see some pictures when it's going!
137905
noseoil
Images: 669
Postby nemoskull » Fri Jan 19, 2018 3:24 pm
the deck is built. im going for minimun weight, so its 1/4 plywood with foam insulation sandwitch. works good. nice and solid. poplar frame. 5x10 on a 4x8 chassis.
the pic gives a good idea of the construction method.
i got three dropped floor/under deck storage compartments, roughly 24 inch square and 9 inches deep. the front most one will probably house the batteries.
nemoskull
Postby jondbar628 » Fri Jan 19, 2018 6:35 pm
Off to a good start.......jd
jondbar628
Postby nemoskull » Wed Mar 28, 2018 8:55 pm
deck is finished. added som square up bolts to the deck.
i went 3d today!
walls are up.
nemoskull
Users browsing this forum: Thunderbolt and 20 guests
