5x8 2007 Wells Cargo build
Re: 5x8 2007 Wells Cargo build
Postby J.Pierson » Fri Mar 09, 2018 5:00 pm
Thanks guys! In the last couple days I have gotten carpet on the side walls, painted the floor, and then I started to cut down the trim rings so that I wouldn't have to build up the wall around the windows as I had originally planned. Things are moving!ImageImage
Sent from my LG-AS330 using Tapatalk
J.Pierson
Postby Iconfabul8 » Fri Mar 09, 2018 5:11 pm
It just dawned on me how crazy some of the things we do look to the rest of the world. When you said you were carpeting the walls and painting the floor, I thought wait a minute, isn't that suppose to be the other way around. Haha :thinking: keep up the good work. It's looking good.
Iconfabul8
Images: 14
Postby J.Pierson » Fri Mar 09, 2018 5:23 pm
Iconfabul8 wrote:It just dawned on me how crazy some of the things we do look to the rest of the world. When you said you were carpeting the walls and painting the floor, I thought wait a minute, isn't that suppose to be the other way around. Haha :thinking: keep up the good work. It's looking good.
The whole time I was working on that it didn't even occur to me that it was backwards
J.Pierson
Postby jmanscotch » Fri Mar 09, 2018 9:23 pm
Great work on restoring the ole girl.
Couldn't help but notice, is your trailer axle welded to the trailer frame, aka no suspension whatsoever?
jmanscotch
Postby J.Pierson » Fri Mar 09, 2018 10:16 pm
jmanscotch wrote:Great work on restoring the ole girl.
Those pictures do look like that don't they? But no, there is a torsion axle on there. It is completely seized though so there might as well be no suspension. Replacing the axle is definitely on my list, but not quite at the top
J.Pierson
Postby Nathan N » Sat Mar 17, 2018 2:59 pm
great job rehabbing the trailer!
Nathan N
Images: 153
Postby dirtsailor2003 » Fri Apr 06, 2018 4:33 pm
Nice work! I just ordered a new 5x8. I would’ve bought used but all the used ones here in constructionopolis are only a hundred dollars less than new and in worse condition than what you got.
dirtsailor2003
Postby jmanscotch » Sun Oct 07, 2018 9:31 pm
Been a little while, curious for an update on this build...
Jake
jmanscotch
Postby J.Pierson » Mon Apr 29, 2019 2:04 pm
jmanscotch wrote:Been a little while, curious for an update on this build...
Jake
I've been meaning to post an update! We got it into useable shape and spent a month in it last summer driving from Idaho to Ohio, Texas, and California with two adults and an 18 month old. It was a blast! I started grad school in the Fall so I really haven't touched it since last summer. I am hoping to pull it out to make some adjustments and use this summer in Michigan. Hopefully I will be able to add a few more pictures in the next month or so!
J.Pierson
Postby jmanscotch » Wed Oct 21, 2020 7:14 am
Jake
Awesome to hear, hope to see some pics sometime of all that hard work!
Cheers
jmanscotch
