I figure I should document my mess so others can learn from it, as I have learned from so many of you. I have been making this thing up as I go along and while I doubt it will win any beauty contests it will be functional...I hope.
The trailer I got off of craigslist for $100 it came with a sail boat. I am still slipping pieces of the boat into the dumpster at work, but the 600lb steel keel and the aluminum mast and rigging got me $74 dollars at the recycling center so if my time is free the trailer only cost me $26... at least that is how I pitched it to my better looking half.
The truck cap was another craiglist score It cost me a $100 all the windows and screens are good, I am trying to sell the back window from it as it is unneeded for my build and if I can find it a new home my truck cap might not have cost me a thing.
The frame has been constructed with 3/4 EMT conduit for two main reasons 1: Its cheap and 2: its easy to come by. I did a lot of interweb research before deciding on this modern marvel of Diy construction material. I had my reservations about it, but I found some forum for backyard air boat builders down in the everglades and apparently it is the material of choice so I gave it a shot. Now that my frame is done aside from a few minor bits I have no worries about my choice of materials...my welds on the other hand are a different story.
The welder is a $89 Harbor Freight Special that by all accounts is the worst welder ever built, but I may be the worst welder ever born so it works out well.
- The frame under way
- IMG_0140.JPG (83.67 KiB) Viewed 3355 times
- Cap on Frame
- IMG_0169.jpg (50.11 KiB) Viewed 3355 times
The attachment IMG_0179.JPG is no longer available
