Ordered a set of these lights a while back and finally installed them in the elf-sized garage space. I can see wanting to reach through the elf door and into a drink-cooler or other bag just inside the garage. Would be nice to be able to see it!
https://www.amazon.com/gp/product/B01N4D2OHQ/
They come with two-sided tape for easy mounting. They're super-light, so hopefully the tape will hold up. Size 10 foot for scale.
Mounted the spare tire on the rear, driver-side and you can also see the four mounts for the aluminum table. It's stored on the inside on another four clips.
The tire is mounted into the wall studs with this bracket. It's threaded rod with a piece of 1" square tubing. Here it is prepped for paint...
I'm running all the wires for the pump, lights, fan, and other accessories back to a panel that's just rear-ward of the access door on the passenger side. As a wire gets routed I'm trying to keep them organized. My wife helped with the label maker.
What is going on here? Stay tuned for that project. Hint, it involves these nifty strip lights. https://www.amazon.com/gp/product/B00HSF66JO/
