Rancid grease in cast iron.
Postby slowcowboy » Thu May 31, 2018 5:47 am
Rancid grease in cast iron skillet do you dare let water touch with soap your cast iron????..thoughts...slow.
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Re: Rancid grease in cast iron.
Postby John61CT » Thu May 31, 2018 6:27 am
Of course if you need to.
If you have otherwise been caring for it properly, only a light re-seasoning is required.
John61CT
Postby swoody126 » Thu May 31, 2018 7:30 am
wipe a/o scrape all the offensive grease away
set on stove full of water and boil out as much more as you can
then wash gently w/ Dawn(mostest gentlist i know of)
fill w/ CRISCO and return to stove to fry 3 batches of potatoes(throwing the potatoes away of course)
pour the grease out n wipe as dry as you can
CRISCO doesn't get rancid as easily as some of today's designer lubricants do
folks who use or wipe their iron out w/ designer a/o bargain basement lubricants will face your dilemma on a more regular basis which is a MAJOR PITA :-O
sw
swoody126
Postby chezrad » Fri Jun 01, 2018 9:09 pm
Put it on the grill outside, crank up the heat and burn it all off. Turn off heat and let cool.
Wipe down with organic flaxseed oil. Heat on grill to 350 for an hour. Let cool.
Repeat 5 or 6 times.
Best finish out there.
chezrad
Images: 24
Postby The Teardrop Nanny » Mon Sep 03, 2018 7:01 pm
When storing it with the lid on use a paper towel as a "wick". Fold it so that it like a long candle and put part of the towel into the dutch oven, replace lid, and let the other part hang over the side/outside. Joanie :)
The Teardrop Nanny
Teardrop Muse
Postby John61CT » Mon Sep 03, 2018 10:32 pm
The Teardrop Nanny wrote:When storing it with the lid on use a paper towel as a "wick". Fold it so that it like a long candle and put part of the towel into the dutch oven, replace lid, and let the other part hang over the side/outside. Joanie :)
What does this accomplish and how?
John61CT
Postby bobhenry » Tue Sep 04, 2018 9:22 am
I experienced this a few times and then switched to coconut oil. Since I have made the switch I have not had the problem. For long term storage I get the iron good and warm and apply 100% bees wax inside and out.
Images: 2463
Postby The Teardrop Nanny » Wed Nov 07, 2018 4:49 pm
Folding a paper towel like a long pencil shape, inserting it into the DO so it touches the bottom, then putting the remainder draping on the outside acts like a wick to absorb moisture when the lid is then replaced. The towel stops the lid from sealing closed tightly and the towel helps to soak up water/excess grease that can accumulate when a DO is stored totally closed.
Joanie
The Teardrop Nanny
Teardrop Muse
Return to Cast Iron
Users browsing this forum: Google [Bot] and 0 guests
