Lifting roof XPStream - Almost Finished!
Re: Foldable foamie hybrid trailer
Postby Atomic77 » Fri Jun 01, 2018 6:48 pm
Looks good! That's a good idea!
Sent from my SM-N950U using Tapatalk
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby OP827 » Sat Jun 02, 2018 9:36 pm
Atomic77 wrote:Looks good! That's a good idea!
Thanks Michael :thumbsup:.
Michael, I am looking to buy primer and paint for trailer exterior. Ordered Homeright super max HVLP gun online, it has good reviews on youtube, I do not have a big compressor for a normal air spray gun. Currently considering topside marine high gloss white paint 1k polyurethane Brightside(https://ca.binnacle.com/p235/Interlux-Brightside-Polyurethane-Gallon/product_info.html) or Mega Gloss White paint(https://www.poolandmarinepaint.com/index.php?l=product_detail&p=23). What kind of primer should I use if any? Any comments? Thanks for advice.
OP827
Images: 405
Postby Atomic77 » Thu Jun 07, 2018 11:35 pm
I'm sorry Oleg... I can't really speak to this because I don't use those types of materials. What you are talking about is a single stage product, which I never use for many reasons. Primarily because if something goes wrong, i.e. fish eyes, runs, dirt, etc. It is very difficult to repair. I only use basecoat/clearcoat products. More forgiving, easy to repair. Look into that before you buy. Good luck!
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Fri Jun 08, 2018 10:08 am
I'll look into that, thanks my friend!
OP827
Images: 405
Postby OP827 » Fri Jun 08, 2018 9:08 pm
Some photos of finished access doors:
Worked much better in one step than when previously I had to fill the cloth weave of fiberglass with two more epoxy coats after lamination (old photo) ..:
OP827
Images: 405
Postby Atomic77 » Fri Jun 08, 2018 9:11 pm
Looks perfect! Maybe you should build some boats with me!
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Fri Jun 08, 2018 11:01 pm
Atomic77 wrote:Looks perfect! Maybe you should build some boats with me!
Thanks Michael!
OP827
Images: 405
Postby Ottsville » Sat Jun 09, 2018 5:11 am
I've only had time to look through the last 5 pages of this build...but WOW! Beautiful work!
Ottsville
Postby Feen » Tue Jun 19, 2018 4:15 pm
I'm planning to glass my build and was intending to just use chopped strand mat, until I saw this! What a fantastic finish!
Where about in Bruce County are you?
James
Feen
Postby OP827 » Wed Jun 20, 2018 8:51 am
Thanks James, I am in Port Elgin. Are you in the area? I think epoxy with cloth is better than polyester resin and strand mat because it it lighter and better finish for similar cost.
OP827
Images: 405
Postby OP827 » Wed Jun 20, 2018 8:53 am
Ottsville wrote:I've only had time to look through the last 5 pages of this build...but WOW! Beautiful work!
Thanks!
OP827
Images: 405
Postby Feen » Wed Jun 20, 2018 3:34 pm
My wife is from Sauble. So I've been there couple of times a year for last 12 years. Her Mom has only just sold up however so now heading to Strathroy from now on.
I've just booked flights to come over next month.
I'll look into epoxy nearer the time.
James
Feen
Postby OP827 » Sat Aug 04, 2018 7:58 pm
Hi everyone. Time to do some update. My progress is quite slow, but I finally figured our how to make the door's transition, lower and upper parts and mostly done with that. Upper door half will have some window cut out after glue is set. Then I'll laminate the upper folding walls with fiberglass. Lower door got laminated with glass using gift wrap to save epoxy and time. Did some pictures of the RV lock install, it was unusual comparing to normal door lock, but doable. Still lots to do, but it feels like the finish is not too far anymore. There will be some fairing and sanding and more minor lamination in the back, but hopefully it will not be holding me up with "thinking" of how to make things.. cheers and all the best.
155623155622155621155620155619155618155617155616155615155614155613
OP827
Images: 405
Postby OP827 » Wed Aug 08, 2018 8:50 pm
What do you think of such of tie-down latch design ? This is a dry fit of the wedged plywood piece that will be anchored to the lower part wall and laminated with fiberglass. It will have rounded edges, of course, once I figured out the best looking shape.. Thanks for your input.
155665155664
OP827
Images: 405
Postby OP827 » Sat Aug 11, 2018 10:53 pm
Tried to mock up the other type of hook today and it looks a little better to me, looks like less of impact or footprint.
Another positive point is that rubber will not damage fiberglass like rattling metal parts and no need for a locking/safety pin or a paddle lock like in the previous version above..
Anybody did something like this and can share experience with the holding hooks here?
Please don't hesitate to say what you think about it ... or everyone is busy camping..?
Thanks for looking.
OP827
Images: 405
