flboy wrote:I used paneling in the CTC, but in the past, I actually used a good drywall spackle on plywood. It seemed to be fine. When you paint over it with a good latex paint, it will absorb in and cover it and essentially bond it to the wood. That has been my experience with it. It shouldn't go anywhere.
FlyBye wrote:flboy wrote:I used paneling in the CTC, but in the past, I actually used a good drywall spackle on plywood. It seemed to be fine. When you paint over it with a good latex paint, it will absorb in and cover it and essentially bond it to the wood. That has been my experience with it. It shouldn't go anywhere.
Thanks,
I just picked up what I hope is some "good drywall spackle", DAP Walboard Joint Compound (Compuesto para uniones de paneles de pared - whatever that means :-). I'll test it out on separate area first and see if I'm up for it. If not, we'll just paint over the plywood as if that's the look we were aiming for!
McDave,
The area I was aiming for was the all of the walls, not just a localized spot. Thanks though.
hankaye wrote:According to a Free translator from the web-a-verse your " Compuesto para uniones de paneles de pared "
ends up being " Joint compound wall panels "
Don't ya just enjoy the things that these electronic slabs can do for ya ???
hank
beachguy005 wrote:Try this product...
https://www.homedepot.com/p/Durham-s-Ro ... /100184116
Users browsing this forum: Bing [Bot] and 5 guests
