Off Road Grumman 2ish (5x5x10) Build
Re: Off Road Grumman 2 (5x5x10) Build
Postby Staryder61 » Mon Apr 30, 2018 5:02 am
DWT77 wrote:Been working on the electrical in the tongue box. I wanted to get all of the components and holes mapped out before I started painting the inside. I also need to finish fiberglassing the exterior and lid
Wow, the electrical wizardry that goes into these little tow boxes is something else.. Who knew that in our younger ages we should have all studied electrical engineering?
Great Job, DWT, :thumbsup: :thumbsup:
I remember here in the forum somewhere, that for backup lights, someone just attached the lights where they wanted them and a switch on the front of their teardrop for those lights. When they arrived at the campsite, they'd step out, flip on the switch for the lights, back in and then turn off the switch. Seems like an easy fix for backing in at a campsite..
Stay safe, David
Our CTC
6' X 12' CTC = Texas Sized Tackle Box
Staryder61
Images: 528
Postby clamlamp » Mon Apr 30, 2018 10:53 pm
Beautiful work on that tongue box!
Sent from my ONEPLUS A3000 using Tapatalk
clamlamp
Postby DWT77 » Sat May 19, 2018 8:52 pm
Cut out the hole for my MaxxFan
I had a little bit of a gap where the ceiling didn't adhere to the frame. So I through some glue in it and clamped it up
Started on the first layer of the insulation. This is 3/4" insulation so I used my router with a dado bit set at 1/2" to cut out my wire channels.
I'm going to make the wire look better this is just a test fit.
I used a 1/8" notched trow to glue down the insulation. I kept the direction of the glue the same like laying tile so air could escape but still had a problem with the insulation popping up. I decided to screw some board to help keep it down. Possibly doing some kerf cuts would of helped make the insulation go around the curve better instead of clamping it down like I did.
DWT77
Images: 473
Postby DWT77 » Thu May 24, 2018 9:12 pm
Wiring the USB/12v Cigarette outlets
Running the wires in the cut out insulation channels
Checking the fan fitting
Cut the hole in the bulk head for the galley wiring
A buddy helped with installing the roof. The fittings I was going to use for running the electrical/wires from the teardrop to the tongue box weren't going to work. So we did everything but that area. I will have to piece that last part in tomorrow after running to the store for different fittings.
DWT77
Images: 473
Postby DWT77 » Wed Jun 06, 2018 8:51 pm
Lining up the holes for wires that will come from the teardrop to the tongue box
I used Liquidtight Flexible Non-Metallic Conduit and Connectors to run the wires through. To secure them I used a lock nut and washer, As hard as it was to line everything up if I were to do it again it may be easier just to run the wires down through the floor and up the bottom of the tongue box and then water seal everything.
Did a half inch round over on the roof. I put blue tape on the sides before setting the roof on that way could snap a chalk line to staple the spars
DWT77
Images: 473
Postby KTM_Guy » Wed Jun 06, 2018 10:05 pm
Looking good.
KTM_Guy
Images: 193
Postby DWT77 » Thu Jun 07, 2018 4:15 pm
KTM_Guy wrote:Looking good.
Thanks KTM!
DWT77
Images: 473
Postby clamlamp » Sun Jun 10, 2018 10:20 am
Fun watching your build, gives me the itch to build another... I like your storage compartment underneath.. now I really wish I Incorporated something like that
clamlamp
Postby DWT77 » Sun Jun 10, 2018 1:05 pm
clamlamp wrote:Fun watching your build, gives me the itch to build another... I like your storage compartment underneath.. now I really wish I Incorporated something like that
Thanks clamlamp! The storage underneath has definitely made the teardrop bigger and it didn't help I put wheels/tires on it to match my TV. My plans were to pull it with a Jeep Wrangler but I feel like it might be a bit much for the Jeep. Maybe short trips would be fine. So I'll probably end up getting a Tacoma to pull it. My thought was the jeep doesn't have much storage so I could add some in the teardrop. Plus hopefully one day I will get to do some long term travel in it and the storage will be nice. Hopefully my plans all work out. I said I only wanted to build one but we'll see lol
Which reminds me of a quote
Making plans is antagonistic to freedom - Forrest Fenn
DWT77
Images: 473
Postby Staryder61 » Sun Jun 10, 2018 1:41 pm
DWT77 wrote: I said I only wanted to build one but we'll see lol
Lol you two, "Who's got the tear Bug"? :lol: ;)
I'm still working on trying to get ours finished. And have thoughts of what I would do the same or what changes I'd make to another one.
Both your tears are great builds.. :thumbsup:
Enjoy, David
Stay safe, David
Our CTC
Staryder61
Images: 528
Postby ojgrsoi » Wed Jun 13, 2018 9:14 am
Nice job.
Mark
Weatherford - True Texas
https://youtu.be/BKs6XfgAKKc
ojgrsoi
Postby DWT77 » Wed Jun 13, 2018 8:41 pm
ojgrsoi wrote:Nice job.
Thanks ojgrsoi!
DWT77
Images: 473
Thanks ojgrsoi!
DWT77
Images: 473
Postby soapcreek » Fri Jun 29, 2018 4:47 pm
This is turning out great. Enjoying your videos also. I’m lucky if I remember to take pictures. Kudos to you.
soapcreek
Postby DWT77 » Fri Jun 29, 2018 9:38 pm
soapcreek wrote:This is turning out great. Enjoying your videos also. I’m lucky if I remember to take pictures. Kudos to you.
Thanks soapcreek! I just took a look at your build and it looks like it is coming along nicely. I like how you did your tail lights. I don't think I have seen that look before.
DWT77
Images: 473
Users browsing this forum: No registered users and 39 guests
