KCStudly wrote:Sorry if this "clogs" up your thread, but I hope you find it to be helpful information and that it contributes to your decision making process.
Not at all KC. Thank you all for the very helpful discussion!
Feen wrote:When you say 6 oz, how big an area weighs 6 oz? A square yard or a square foot?
I'll be using 450gsm mat for the walls and probably 600 gsm for the underside. My build is a slide in pod so the base needs to be fairly tough.
I should add that I use GRP at work for flat roof coverings so I have the materials on the shelf.
James
Carl01234 wrote:I am about to the epoxy stage on mine. This guy did a very good review on 6 brands, including the Raka 350 http://www.oneoceankayaks.com/Epoxresl.htm
...but want to coat at least the underside with epoxy...
Epoxy by itself is not very sturdy...
tony.latham wrote:Epoxy by itself is not very sturdy...
KC:
You're right of course with that statement. However, when epoxy is applied to wood, it wets into the surface and becomes a wood-fiber/epoxy matrix. It's not like a sheet of brittle plastic glued to the wood. (I use Raka's 127 thin resin for sealing, but I would think any slow-set epoxy would end up with a good wetting.)
The plywood I've epoxied on our teardrop hasn't changed in five years and a few thousand miles of use. It still seems bulletproof.
(But I have yet to discharge a weapon at it.)
Feen wrote:My bad, I haven't researched the epoxy/polyester thing. I'm just sticking with what I know.
I'm afraid to ask about the pros and cons of each.
Incidentally Tom, I've just bought a 3/4" round over cutter for my router. It's as big a cutter as I'd like to use in a hand held. Although (currently) I'm not planning to use trims on the external corners, I think I'll probably paint them on just to add some detail against the white walls. I'd opt to do them in bedliner (Upol Raptor) along with a stone chip area around the skirt.
James
Carl01234 wrote:I have used 5 or 6 different brands of epoxy. My bigger uses were to build large aquariums with plywood. I never went heavier than 4 oz cloth. 4 oz will be easier on the corners. I have never wore a respirator while applying, but you definately want one while sanding. Your router will not have a problem with the glassed plywood. But wear very good eye protection and long sleeves.
KCStudly wrote:The pumps are really helpful to control the dispensing process, avoiding over pouring and wasted material around the necks of the cans. It is a much neater and controlled process for getting material out of the cans, so even though I am using a cheap $13 digital scale, I still use the pumps. I would second think about getting a gram scale; the first time you screw up a batch and waste a yard or two of cloth, it just paid for itself, not to mention your effort to clean up the mess and try again (I had an area on my hatch that never set up, so I switched to the scale instead of trusting my ability to count using just the pumps... haven't had an issue since).
Epoxy by itself is not very sturdy (nor is the glass cloth). But together they are greater than the sum of their parts. Wood can still check, dent and/or splinter (especially under stress) and straight epoxy can't really offer much shear or tensile strength to resist that. If you are expecting it to some how magically "armor up" a surface... not so much. IMO, if you are using epoxy as a sealant and want it to be extremely durable, go ahead and use at least one ply of glass cloth to get the best benefit. Sure, you will have to spend more time and money to fill the weave and apply a top sealer coat, but in for a penny in for a pound. Doing it part way is almost not worth doing it, IMO, because you could be wasting the added expense to a short term result; especially on bent (i.e. stressed) plywood. YMMV.
I saw mat mentioned above. As I understand it the binders in mat are only compatible with poly and vinyl-ester resins, not epoxy.
Yes, glass cloth ounce weight is by the square yard, unless specified otherwise.
