I did my first trip yesterday, just a one nighter. I ended up staying at bonnechere provincial park as I identified a roof leak and made some minor quick fixes to hopefully resolve .. unfortunately not, as I found out during the heavy thunderstorm and downpour all last night. I did go with the tarp poles 'for now' because I already had that.. and thankfully, I was able to just flip the whole contraption over top of the roof and kept the most of the rain off. Looks like i'm going to be pulling out my skylight window completely now..
I DO want to get a canopy eventually. I just have trouble justifying the expense.. the ones I see around here are generally $800 and look like they'd disintegrate with the first small gust. I want to head over to cabellas one of these days, as I've heard rumors that they have something much sturdier at around $650.
It leaks through the butyl tape... after I lifted the tape off, I found out why.. It wasn't sticking to some areas, as I thought, there was some silicone residue. SO I'm going at it with some mineral spirits after I get it dry, removing the skylight completely.. repainting the areas where the paint came off with the tape/mineral spirits. After that, i'm getting a larger piece of lexan, that will cover the whole opening in the roof the outside will be lined with butyl putty and then I will be screwing that lexan down to the outside of the frame where my home-made window once was.
Should have done that in the first place, but I just *had* to be fancy. Don't hire me to make your windows, apparently.
- before the sky poured on me
- wedgesmall.jpg (298.51 KiB) Viewed 2369 times
The other things I learned, are.. solar panels sitting in the sand during a rainstorm get absolutely covered with sand, and water. Since they are stored under my mattress.. I wasn't too happy as I put them away, I was able to wipe them down pretty well but I think I need to have an alternative, or simply mount them on the roof and be done with it.
I also found out that having sleeping clothes in a bag in the corner, with clean clothes sucks. I want to get a cargo net or something to either put on the ceiling or on the wall for that purpose. Same goes for laptop, etc.. which ended up sitting on top of my battery box. They need a shelf or something. Third.. cheap inverters are great until they are not. The fan header failed, on my 'good' one, and it refused to start.. I replaced the fan, and same deal. So.. i had a cheap canadian tire special in my car for backup purposes, 400 W modified sine. Unfortunately, it couldn't run a 250w laptop power supply.. it also struggled to run even a 10w power adapter for my screen and at the same time a 15w tv tuner which I also tested during the rain storm. Of course, no signal to be found.
On the bright side, between rain storms I was able to set up my kitchen on the picnic table. Quick and easy faire this time, no fancy culinary delights. for lunch I had a simple mr.noodles type packet, and for dinner I had a can of bush's beans n ham. I have a collapsible silicone pot with strainer lid and a small collapsible camp set with enough utensils for one person. I also have a simple butane stove with one burner, all that fits in a small bag and cleans up extremely quickly. 2 cups of water boils in less than 5 minutes and I was able to eat and clean up in less than 30 minutes. Quite nice. (also quite nice to have if you end up doing a day hike)
https://seatosummitusa.com/products/x-pothttps://lightmyfire.com/products/mealkit-bio-8-pcshttps://www.trailspace.com/gear/brunton/talon-butane-stove/I was happy to find out that positioning the trailer by hand is still doable, but as I get older I think getting a wheel for the front instead of the current flat post would be wise. For now, I have a couple of axle stands to keep things stable, but I want to get proper leveling jacks for all four corners, and a couple of bubble levels in the appropriate places not the highest priority, but on the list. Probably won't be doing any more travelling with it till next year at this point, winter will be here fast, and my new job provides 3 weeks of holidays, two of which I've used now.. and the last one is being saved for Christmas. Miss those 4 weeks, but just glad to be in the black again.
Amazon order with some of the stuff for the skylight repair should be ready to pick up from the depot tomorrow, so I'll probably head into town and swing by the hardware store to try and get the lexan and appropriate wide headed screws (or washers failing that) to hold it down.
"In the morning, the light is golden, in the midday 'tis time to nap, and in the evening the light returns. Into the night the stars shine brightly, now if only the moon would stay out of sight." - Some photographer
